Pride Jazzy 1103 Ultra Standard Power Chair  Logo
s
sharane ambrose Posted on May 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We had the batteries replaced on 3/30/16 and now the red light is constant and when we charge it .. nothing changes... it barely moves and I do not believe it charges... the batteries are new
Jesse Walters
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 337 Answers
  • Posted on May 13, 2016
Jesse Walters
Expert
Level 2:
Mentor:
Answers
337
Questions
0
Helped
102221
Points
640
They have complicated control computers and are very touchy concerning the amount of voltage in various parts of the system, such as how much current the motor is drawing. Sometimes transmissions go dry of oil causing the gears to bind, throttles develop oxidation on the contacts, terminals get corroded. I had to bypass my original unreliable controller completely with a DC variable speed board from China. Test your batteries by connecting each to their own standard car charger. Get the back wheels off the ground with blocks and test run the motor while connected to the chargers. And test each battery with something powerful that can determine its strength, not just a small test light.
The chargers are reliable, but the control brain (module) maybe not. Make sure your batteries are not dry, make sure fuse is OK, terminals are clean, charging system must be unplugged to run, test test test. Make sure the speed limiter is tried in various positions, parking brake or lock is in correct position.
Testimonial: "what I do not understand is why the light is on. I am not technical and he is disabled. I tried to get the place that replaced the batteries to send the guy out and now they say no... I am lost and not a happy camper"
I have bought Dewalt 20V DCB107 drilling machine with 2 batteries. Both batteries are not charging first time itself. The charger red light constantly lighting but not blinking
I DON'T KNOW. COULD BE UNDER WARRANTY FOR FREE REPAIR OR REPLACEMENT. I HAVE RYOBI AND UPDATED ITEMS. THEY HAVE 3 CHARGERS 2 SMALLER RATED CHARGERS WOULD NOT GIVE ME
'FULL CHARGED' LIGHT. OLD BATTERIES WOULD NOT CHARGE ON OLDER CHARGER. FROM INTERNET ADVICE, I REPEATEDLY PLUG AND UNPLUG CHARGER BY HAVING PLUG LOOSE WHEN DOING THIS. SOMETIMES IT TAKES 4 TIMES TO CHANGE FROM DEFECTIVE TO CHARGE. SOMETIMES IT TAKES 20 TIMES TO SEE THE CHARGE LIGHT.
When switched on red light is constant but as soon as I try to move the light flashes constantly, no pauses.
Hi get you're batteries LOAD TESTED to check there condition .U can buy a load tester on E/BAY FOR aprox $30 to $35 this will give U an accurate test on there condition ..good luck
2answers
Battery charging flashing
When you say the battery has been stored for two years, I hope you removed it from the camera before storing it. Otherwise, the terminals may have corroded and damaged more than the battery. If nothing is corroded have the battery checked. Sitting unused for that length of time may have shortened the battery's lifetime considerably.
2answers
Off-on switch as bright as when it was new. green light on charger indicates the battery is fully charged. turn throttls and bike barely moves..... ?????
check voltage with a multimeter set on volts before trying to trottle and then after you trottle it should close to the same voltage. If not then you need to replace battery.
7helpful
2answers
Battery flashing when charging why?
If the red light is flashing after inserting a NP-20 battery in the Casio Lithium Charger BC11-L, it means that the battery will not take a charge. Normally when putting the batterry in the charger, the light will be a constant red. After charging is complete, the red light will go out. Battery is then fully charged and ready for use.
1helpful
Red light on my jet 7 keeps blinking and chair barely moves.
Sound like the batteries are on their last leg. Have them load tested.
1helpful
2answers
Red Light!
Hi xx
It sure does sound like a battery. If it is more than 12 months old, and regularly charged(daily) , then it will need replacement.
regards
Graeme
2answers
Charging of the casio exilim battery
Blinking light means charging error. Call tech support and they will replace battery for you for free.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
