Heidi, No electric release. The latch is probably stuck. While you pull the interior hood release have an assistant push down and pull up repeatably/vigorously until hood releases from stuck position. Lube latch and cable before closing hood. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Open Hood How To 2001 2005 Audi Allroad Quattro 2002 Audi Allroad Quattro...
2007 Audi A4 2 0t hood latch fix when you can pop the hood
Hood Latch Release Cable Broken How to open hood
Help Hood release cable disconnected somewhere any ideas how to open hood...
Testimonial: "Next. Replaced the battery but now seems to need some codes reset. Power windows don't work , power mirrors don't work, top doesn't work and airbag light is on . Any suggestions to reset the codes. Can't put windows down ."
Well next suggestion lol.It didn't work
Most towing services or a locksmith may be able to help you out, tell them of your situation when you call, then they can bring required tools and materials to get hood open, so as not to waste your or their time. Good luck Press the helpful button if you feel I was of assistance.
Heidi, sorry I do not know the reset procedure, you could try google search,check your manual or ask the dealer.
