Bunn 10 Cup Home Coffee Brewer Logo
D
Debra Posted on Apr 09, 2016
Coffee grounds in bottom, using Bunn coffee filters
5 Related Answers
Danobegood
  • 5 Answers
  • Posted on May 23, 2008
SOURCE: Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Edward Jennejohn
  • 244 Answers
  • Posted on Oct 09, 2009
SOURCE: Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Anonymous
  • 189 Answers
  • Posted on May 19, 2010
SOURCE: Coffee grounds overflow
Tressia,
An overflow can occur when using certain brands of coffee that are finer ground or using a water softener, bottled water, reverse osmosis, or filtered water. If you will call Bunn Customer Service, you can get a flow restrictor sprayhead which will eliminate this issue.
Anonymous
  • 189 Answers
SOURCE: my bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Anonymous
  • Posted on Dec 02, 2012
SOURCE: Bunn thermofresh makes very weak coffee
I don't know what the flow restrictor looks like, but I know what a spray head looks like.
My new Bunn BTX-B brewed weak coffee also. I was wasting coffee to get it stronger. I decided to inspect the spray head. What The hey! What Spray Head? The coffee maker didn't even have one. I guess the assembler forgot to put it on. Yet it made it thru quality control. No wonder it was making weak coffee, and I was wasting coffee to try get it stronger.
Is your making weak coffee? CHECK YOUR SPRAY HEAD. Make sure the coffee maker has one on it.
6helpful
Tressia,
2helpful
Water fills the filter and overflows with coffee and grounds. why?
Are you using the original Bunn pot (carafe) or a replacement ?
At the bottom of the filter basket, there's a little lever that closes off the coffee flow when you remove the coffee pot. The idea is that you can pour a cup early, before the full pot is brewed, and it won't spill coffee all over the hotplate.
The original coffee pot fits right against this little lever, but if you have a replacement that's not the right size/shape, it won't reach the lever.
If this helps, please be sure to hit the thumbs-up for me.
If not, use the "add comment" and let me know what's up, and I'll do what I can to help!
1helpful
Grounds in coffee. am using bunn coffee filters and still have a mess in my cup and in filter
Are you using a finer ground coffee? Or do you have a water softener, use filtered water or bottled water? If so, please call customer service to get a flow restrictor sprayhead which will eliminate this issue.
Coffee grounds in bottom of commercail size coffee maker
If you will call 800-286-6070 we can help you with this.
2answers
good luck!
Brewed coffee mess
You may be grinding the coffee to fine making the draining a little slower. There's something called a fast flow filter that may help also. Also, make sure that you aren't jamming the filter down to partially block the drain hole ensuring that it is freely draining out unobstructed
Bunn coffee maker
An overflow can occur when using certain kinds of coffee or the use of a water softener, bottled water, filtered water or reverse osmosis. If you will get the model and date code located on the bottom of the machine and contact customer service, a flow restrictor sprayhead can be sent out to you that will eliminate this problem.
2helpful
2answers
Coffee grounds leaking out of the basket
When you are grinding your own beans or use certain types of coffee, you need to use a flow restrictor sprayhead. If you will contact customer service, a flow restrictor sprayhead can be sent out to you at no charge and this will eliminate the problem you are having.
3answers
Grounds splash from basket into carafe
My brother has a Bunn that does the same. I think the coffee filters he is using are too short. If you think this might be the problem too, try an internet search for Bunn coffee filters. Hope this helps!
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
