Samsung SCX 4521F All-In-One Laser Printer Logo
A
Anonymous Posted on Apr 06, 2016
When printing the sheet comes out half black
Changed my toner in Dec 2015. It was working perfectly until yesterday when the sheets come out half black. I tried to clean the roller which had toner on half of it
WTF Chuck.....
Level 3:
  • Master 388 Answers
  • Posted on Apr 07, 2016
WTF Chuck.....
Master
Level 3:
Answers
388
Questions
Helped
98689
Points
1224
Sounds like the Photo-conductor is going bad. If it's a separate part in your printer, you just might want to change it out. Otherwise it might also be built into the toner cart, and you'll need to get a replacement toner cart. Not usual but, i've seen a few bad toner carts.
Hope this points you in the right direction.
Thanks!
Please Rate:)
Gary
Why is my printer only printing a black sheet of paper?
Hi it is not the toner but it could be a developing unit or transfer roller.
But since on b6500 the developer unit is changed with the toner it is probably the transfer roler or HV unit.
Regards
2helpful
Laserjet 4050 - black streaking on right hand side of page
It is either the toner cartridge or the fuser.
Put paper in the manual feed tray.
Print the Configuration Pages.
When the sheet is half way fed into the printer, open the top cover.
Remove the toner and look at the sheet of paper. If you see the black streak, the toner is bad.
If the sheet looks good, the fuser is bad. Probably a bad roller, which you can see looking at the fuser.
I have a HP 8100 printer, when i print a configuration page, the top half of the sheet prints very light(blurr), while the bottom half of the sheet prints good. At first i thought it was the toner, so i...
There is a good chance the laser unit polygonal mirror is dirty. It spins at high speed and the lead edge generally gets dirty. Try removing it with care, cleaning the polygonal mirror and the lens's in the lazer unit
1helpful
Samsung 315 black color fades after 200 of 250 prints
remove the toner cartridge from printer and shake it well and insert it back and see the result of print
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
HP J5680 is printing and scanning vertical gray stripes
The fix is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=za&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2answers
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Hp psc 1510 prints reddish-pink color
the photo come out pink and i buy yesterday can you help me hp 1510
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
