Checked that selector is working. seems like clutch is not releasing
Howdy SP Le Roux... from Sunday after 4pm... yesterday... West coast... East rim of the Pacific (SF Bay area).
Pretty sure you not here... (USA) We haven't deliberately imported
Renault for 30+ years... although in the 60'ish... I did enjoy the engineering that went into the wonderfully ROBUST Duaphine engine... (under-rated & seriously mis-understood here).
On a hunch... I looked on eBay and found plenty of 2006
shifters... and sure enough... they had those wonderful little cables.
I'd be willing to bet... you have a broken cable... You will need a partner to verify... because getting under a car... and then putting the VERY SAME car you are under can be risky at the very best..
Make sure it is an expendable buddy if you are in the drivers seat... or a DEAR TRUSTED FRIEND... If you are the one under the car...
Better idea: fully secure the car w/jack-stands...
Hoist would be best.
I'm just saying ... Hope this helps!
2006 RENAULT MEGANE 1 6 Petrol Gear Shift Linkage Gear Stick
Just for the pictures... New cables will make your car last another good service life... You will be proud
Check there is free play at the clutch arm at the gear box, if ok a broken axle could this, if a 4 wheel drive check the transfer leaver is not in neutral .
Do you know if this AUTOMATIC or MANUAL transmission?? My research sez '06 Megane (auto or manual).
