Are you sure that you are starting each button hole with the buttonhole slider foot back at the front? I know that they are usually spring loaded but is possible that yours isn't returning fully to the starting position.
Also, it is important to prepare the test buttonhole on a fabric sample identical to the garment you will be buttonholing, ie two layers with interfacing between.
I am trying to think what else could be causing this to happen for you. Are you going through the process where you stitch out the first buttonhole, then save this length and then repeat it multiple times. Or using the button in the back of the foot to provide the size of the buttonhole where there is a buttonhole trigger you slide down in place near the pressure foot.
If you have tried and followed the manual precisely and still arent getting a correct buttonhole out of the machine, then perhaps consider taking it to your local dealer and asking them to watch you go through the process and see if they can spot the problem; this should help identify if it is a machine problem or something you've missed in the process.
Are you using the buttonhole foot when you try? It will look like this.
Also, there is a lever you need to pull down to deploy when stitching buttonholes. It triggers the machine to stop stitching out the side of the buttonhole, reverses then does the other side. Its a little lever up in the head near the pressure foot bar and needle bar. It will touch the sticking out finger on the buttonhole foot to trigger the reverse motion in the programm.
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Look for the buttonhole lever, just in front of the presserlever, on the lefthand side of the machine. Pull it down and push it back to the top. Good Luck
Look for the buttonhole lever, just behind the needle threader lever. Pull it down and push it up again. The machine gives a warning message if you want to sew and the button hole lever is down.
Look for the buttonhole lever, just behind the needle threader lever. Pull it down and push it up again. The machine gives a warning message if you want to sew and the button hole lever is down. Good luck!
