SC 544
Heating roller thermopile (center) error 3
The thermopile detected a temperature over 260?C.
TRIAC short, AC drive board defective
Defective IOB 2
Defective BCU
Related SC code: SC 553, SC563
1.
Do SP5810 to cancel the SC fusing code.
2.
Replace the AC drive board.
3.
Replace the IOB 2.
4.
Replace the BCU.
GO TO SERVICE MODE AND SP5810 to Clear - Check temp inputs - SP5803 150, 151, 152
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
SOURCE: SC544 functional problems ERROR CODE ON REX ROTARY 1808D COPIER
fuser problem. Call for service
SOURCE: error code SC998 on Ricoh Aficio 1045
The error code 998 is usually for the dimm or application boards read errors try taking the memory out and the app board out and reseat them again.. then go into the service mode via yellow clear button and then enter 107 then hold down the stop button till the panel changes and turn off the copier wait for 5 secs then turn back on.. If you dont know where boards are take the back panel off and on the right hand side there is a box with a steel plate on the dimms Ram..and app boards are there.. Good Luck A..
SOURCE: service code sc544
It is a fuser overheat error....really has to be checked by a technician...
note that any Ricoh tech can also do it as it is a Ricoh machine
SOURCE: Ricoh 1022 service sc544
This is a code for the fuser, which indicates a very serious overheating condition. Your machine has something _seriously_ wrong with it, and should be looked at by a service technician.
SC544 - Fusing overheat error 2
A fusing temperature of over 251°C is detected by the fusing temperature monitor circuit in the SBCU board.
Potential Causes:
• Fusing thermistor defective
• Power supply board defective
• SBCU board defective
Hi
SC544 error means Fuser Overheat Error 1 (Hardware). This has happened due to Fuser Low Temperature which occurs due to Abnormal Hot Roller Fusing Lamp Lower Limit Temperature Detected. Try turning off & unplugging the copier for 10-20 minutes to check if error code resets. If it doesn
