The Toy Watch website has instructions on setting the time. Not sure about the date:
Setting Your TOYWATCH
1. Unscrew crown by turning it toward you.
2. Pull the crown out until you hear a click.
3. Turn the crown to set the time as desired.
4. Push in the crown and screw away from you until it is
tight.*
* If crown is loose warranty covering water damage may be
voided.
http://toywatchusa.com/content/Setting.htm
To set the date, wind the time around to 12pm as many times as required to bring the date forward
SIMPLE!
I am working in Toywatch, in common. u have to screw out the crown then one pull for date if available in the model and two pulls for the time..then screw the crown in again to protect ur watch of water. if u need any help contact me on my facebook
https://www.facebook.com/Ghost00Rider
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: setting time and date
I found this document to help me. It is from Armitron. My watch didn't look exactly like the one shown, but the instructions still worked.
http://armitron.com/WatchPDFS/ArmitronLadiesDigital.pdf
SOURCE: Watch setting instructions SEIKO 7N43 8A39 "A1"
If you are still wondering about this, pull the knob out to the first click. turn one way to set day, turn the other way to set date. Pull out further to set time.
SOURCE: Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
