Building Materials Logo
Stacy Bruns Posted on Feb 08, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Craftsman Keyless entry model 132B2386-6 with flashing lights, wont open. Already put in new battery still doesn't work
When u enter the code, the lights flash and the door doesn't open. put in a new battery still doesn't work
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Feb 08, 2016
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067928
Points
28436
Why would my Keyless Entry close but not open the garage ...
www.shopyourway.com > Manage My Life > Questions
Mar 27, 2008 - I have a Craftsman Security+ Keyless Entry, P/N 139.53684 purchased with my ... However, the door will not open, but the keypad flashes as before. ... Check if there is a flashing green light on your wall control in the garage. ... The 2 remotegarage door openers won't open or close the garage door; but the ...
Craftsman garage door opener won't open or close, why ...
Hi, I have a Craftsman 1/2 HP garage door with keyless entry (P/N ... When I click theremote or the wired button, the main lights come on, the motor moves ... Five flashes means that the RPM sensors has most likely stop communicating.
LiftMaster - Support - Videos ' LiftMaster
https://www.liftmaster.com/Customer-Support/Videos
Chamberlain GroupHow to program a wireless keyless entry using your garage door opener's LEARN button. How to ... Why the LED or light on the door control is blinking and my remotecontrol is not working? Why isn't ... Why won't my door fully open? How to ...
I have a craftsman garage door opener, of which I tried to program a new remote. but it did not program. in the event I accidently errased my keypad password. How can I reprogram the keypad, i cannot...
Hello there,
It actually depends on what you are trying to program. And these instructions apply only to openers that do not have dip switches on them.
Remotes: push don't hold the colored learn code button all models have different colors. After pushing the button hold the remote behind your back and push it three times. On the third time the door should run.
Keyless Entry: Program the code you want into the keyless. Push the colored learn code button and then enter the code and push enter three times slowly. on the third time the door should run.
Home-Link. Hold the two outer buttons until the blinking pattern changes. Then hold the button you wish to program and point and click your remote at it. Push the colored learn code button and push the homelink button three times.
There are two models of the Wireless Keyless Entry System, the 740CB and the 940CB. The 940CB is for use only with Security+® garage door openers having an orange/red smart/learn button. The 740CB will work with all openers manufactured since 1990 that have a yellow, white, gray, or green smart/learn button. It will not work with Security+® openers.
To program the keyless entry, first locate the smart/learn button. On our chain drive models, this button is on the end farthest from the door. On our belt and screw drive models, it is on the right side as you face the door from the opener. You simply press and release the smart/learn button. You now have 30 seconds to enter your four digit PIN number into the keypad and hold the enter button for five seconds. Wait one minute and test the keyless entry by entering your four-digit PIN number and pressing enter.
With some Security+® models, you can also program your Model 940CB Wireless Keyless Entry without climbing a ladder, right from your Multi-Function Control Panel. Simply enter your pre-selected code and press and hold the enter button on your Keyless Entry. Then press and hold the light button and the pushbutton on your Multi-Function Control Panel. The garage door opener lights will flash to confirm that the Keyless Entry has been successfully programmed.
Hope this helped you solve the problem. All the best my dear friend. Elect_Comp
2answers
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Cannot get keyless entry to work. Bought new keyp...
That keypad should work with your opener. I suspect the keypad is bad if you have other remotes that work. If not it could be the logic board.
Just bought a new PD210DM opener but still have
I don't know this model. (in australia). the chamberlains here are probably the same. the 4 digit code you first put in the keypad is what you have to use. push the learn button on your operator then punch in your 4 digit No. Hold the enter button on your keypad until the light flashes on the operator.
That should code it in.
freddy51
Craftsman Model 139.53684 Keyless entry doesn't work
The remotes and keypad use the receiver which is part of the logic board.'t The button on the wall is hardwired and doesn't use the receiver. You might pull the logic board and check for bad connections on the printed circuit.
The Chamberlain wireless keyless entry model 940CD doesn't work. I changed the 9 volt battery, but it doesn't light up or do anything when I enter the password. It's like it's totally dead. I've had it for...
make sure it is the right keyless entry. For starters, Make sure your antenna hanging off the operator is "purple" color. If it is grey, you have the wrong keyless entry. The keyless you have is for the 315 frequency. If your antenna from the operator is grey, you need to get another keyless entry based on the frequency.
1helpful
My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
1helpful
Change keyless entry passcode for chamberlain model 4100 door opener
You have to press a Yellow/Purple button on the back of the garage door opener unit.
It is the LEARN button. Then enter a new four digit code into the keypad and press the enter button.
The unit should click and the lights should flash. This acknowledges it has learned the new code.
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
