Nintendo Wii Console Logo
A
Anonymous Posted on Feb 03, 2016
Broke the front panel cable that connects to the motherboard on the Nintendo WII but everything seems to still work. Any ideas what it does?
Aron
Level 3:
Top Expert:
  • Nintendo Master 2,586 Answers
  • Posted on Mar 04, 2021
Aron
Nintendo Master
Level 3:
Top Expert:
Answers
2586
Questions
0
Helped
390313
Points
78544
It could be where you can plug gamecube controllers into and put gamecube memory cards in as well.
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Jan 05, 2009
SOURCE: My Nintendo Wii isn't working
If it's like that with all games it's almost certainly broken, call Nintendo if it's still under waranty.
Bart Fonteyne
  • 130 Answers
  • Posted on Jan 07, 2009
SOURCE: Nintendo DS hinge broke
You can find the info for replacing the shell here:
http://site.powergamingparts.com/RepairNdsl.html
Anonymous
  • 14 Answers
  • Posted on Jan 20, 2009
SOURCE: Can't get my Wii to connect to internet via LAN Adapter.
First thing to verify is that your using the licensed wii lan adapter, then you can go to www.nintendo.com and click on the support link to look up the error codes your getting. Have you called into nintendo to ask if you have a compatible router? may want to try that as well.
androidyl
  • 81 Answers
  • Posted on Sep 29, 2009
SOURCE: Nintendo wii black and white screen
take it to nintendo. that happened to me 5 times
Anonymous
  • Posted on Dec 30, 2009
SOURCE: Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
I m trying to connect Internet but I m getting the error code 51422 Please help what should I do?
1. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
2. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off.
3. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
4. If possible, try another Wii LAN Adapter.
3helpful
2answers
3answers
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
My wii wont turn on checked connections all seem fine
You may need to reset your power cable. Disconnect the cables from both your Wii and the wall and TV so they are not connected to anything and let them sit for 10-15 minutes. This does what Nintendo calls a power cable reset and should fix the error.
No power to guitar!
check the plug in wires to make sure they are not broke
blow into wii remote back port and guitar connecter
We have recently moved home and our nintendo wii remotes have stopped working. i have checked all the connections and have put new batteries in them
Make sure the Wii is plugged in correctly and the light on the power button is on.
open the small panel in the front of the Wii and open the battery panel at the bottom of the Wii remote
and press the red buttons together
If you had been suffering from batteries lasting a little while then Nintendo will replace the controller for free
2helpful
Problem displaying nintendo wii graphics
After more checking around I found out this is not an uncommon problem with the wii. Apparently there is a design flaw that causes the graphics card to overheat, which creates various types of distortion. It may have something to do with using wiiconnect24. I am sending my wii back to nintendo for repairs.
2answers
Blank screen
189
No sound from wii console
Make sure your cable is not messed up
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
