Is the gas cut off lever under the tank suppose to be straight up and down to crank or sideways for the motor to start?
SOURCE: Coleman 5KW gen motor shuts down when A/C switch turned on
Sounds like a problem with the wiring of the outlets after the circuit breaksr. Take apart the outlet box and have a look for burned or broken wires, melted outlets, and/or small critters stuck in the wiring.
I recently had to repair a generator that had its voltage regulator taken out by a frog!
Regards,
Carl
SOURCE: Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
SOURCE: low output from NorthStar 5500PPG
There are a few scenarios that can cause this.
1) The extension cord that you are using is too long / too light of a guage. Try a heavier extension cord, or plug directly into the generator.
2) The alternator has lost its "residual magnetism" and may need to be reflashed. Consult Northstar for instructions and details.
3) The voltage regulator (actually a simple capacitor) may be "weak"
4) The diode for field winding may be bad.
You can get a copy of your manual here, page 40 has diagram and part numbers.
http://www.northerntool.com/downloads/manuals/165911.pdf?cm_ven=natural&cm_cat=netconcepts&cm_pla=Google&cm_ite=http%3A%2F%2Fwww.google.com%2F%26
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
