Mach Speed TRIO Stealth G2 10.1" 16 GB Wi-Fi Black Tablet Android 4.0, LCD Touchscreen Logo
Jack Deluca Posted on Jan 13, 2016
How do I reset after forgotten pattern and it won't recognize my email/password?
I can't remember my password to get in my tablet. How do I reset it?
Forgotten Password ' Android Tablet Forum
www.androidtablets.net > ... > Sony Tablets > Sony Tablet S
Jan 28, 2012 - 11 posts - ‎9 authors
My little brother set a password on my tablet and then forgot it .... is there anyone out... there is no 'forgotten password' and i have tried resetting it so i have to a standstill... alright thanks.... how do i do a complete restore ? How Do I "Factory Reset" My Tablet?
Oct 17, 2013
Forgotten password
Jan 22, 2012
Forgot Unlock Pattern for Coby Kyros
Mar 11, 2011
More results from www.androidtablets.net
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
My big lots tablet is lockedand i cant remember the pin itsa d2 7in.what can i do ?
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
3answers
FORGOTTEN UNLOCK PATTERN
It is quite normal that after providing an unlock pattern to your tablet or mobile, you forget the pattern and attempt unlocking the device multiple times. In this process, many times your device gets permanently locked, and you no longer get any access to it. If you have forgotten your recovery email, you will not be able to unlock the device using that option as well. More.. How Do Unlock My Tablet if Forgot the Unlock Pattern or Recovery Email
How to bypass forgotten snack pattern and login details on samsung galaxy 3
Hi if you forgot your pattern and email the only option is to reset your device to factory default.
How do you reset the password as we have forgotten it
If it's linked to your google account you should be able to reset it. Taken from user manual:
After five wrong entries, you can reset
your unlock pattern. Tap Forgotten
pattern? and enter your Google account
Note: You must have an active
Google account on the tablet and
an Internet connection.
If this option is not available, please
contact your local Acer service
center.
Pattern attempts
If you have it linked to an email account, then if you enter your password 5 times you should get a forgot password button. Click it and follow the prompts to reset the password. You can also reboot the tablet and hold either power + vol up or power + vol down to get a menu with the option to factory reset the tablet. This will erase all data too.
Top Mach Speed Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Mach Speed Tablet and eReader Expert? Answer questions, earn points and help others
