SOURCE: trying to find a
Replacement parts for the Tilia Foodsaver products can normaly be found here:
http://www.foodsaver.com/parts.aspx?search=420
However I am having trouble with your model number. Are you sure it is correct?
Suggest you inquire with the company as to which listed model would be compatible with your model . You may contact them over the web here:
https://secure.foodsaver.com/contactus.aspx
SOURCE: I am on my 2nd
I replace my gasket with a piece of 3/8" Poly Foam Caulk Saver (found mine at Home Depot - @$2.00 for 20'). It's a snug fit in the gasket groove. Cut long enough so that the ends touch tightly. It will create a good air seal and works well.
