2006 Honda Odyssey Logo
Posted on Dec 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What could be wrong with my 2006 Honda Odyssey. It has no heat, but the engine is running hot. I thought maybe coolant level was low but overflow tank was right at max
Claude Kayser
Level 3:
Top Expert:
  • Honda Master 9,098 Answers
  • Posted on Dec 28, 2015
Claude Kayser
Honda Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067968
Points
28436
Temp gauge runs hot but car makes no heat...... HELP ...
honda-tech.com/honda.../temp-gauge-runs-hot-but-car-makes-no-heat-h...
Mar 28, 2010 - Temp gauge runs hot but car makes no heat. ... Honda-Tech Member ... I figured my theromstat was going bad so I replaced that and it did nothing. ... Any help would be awesome, im losing my patience fast and I have a real big hammer ... This is between the engine and the heater core (under the hood).
Overheating Issue - Honda Odyssey Forum
www.odyclub.com/forums/9-problems.../151854-overheating-issue.html
Nov 13, 2011 - 10 posts - ‎5 authors
I have a 2000 Honda Odyssey with 200K+ on the odometer. ... small head gasket leak,but not enough to see coolant pouring out and no ... 4) Bad thermostat (your new onecould still be bad) - Since your engine is getting hot but you are not getting any heat, ... My coolant was changed at 10yrs/150K miles. Thread: 2007 Odyssey LX - cabin heating issues, no heat ...
Nov 19, 2012
Hot air on driver side vents - Cold on passenger side ...
May 9, 2012
Thread: Overheat while idle
Feb 29, 2012
Thread: No or very low Heat - Wife Is Pissy
Dec 13, 2010
More results from www.odyclub.com
3answers
2006 jeep grand Cherokee limited if the radiator overflow jug is empty will it cause the transmission temp light to come on
I would say it is possible an overheated engine which is not coolling the transmission can trigger a lot of lights. Many transmissons are heated and coolled by a line which goes to the radiator of the engine cooling system.
2helpful
2answers
My 2006 Caravan temperature gauge goes to red - engine is not overheating. Kick it into a lower gear (automatic trans) and the gauge comes back down. Is it likely the coolant sensor?
Could be.. is the system FULL? Air in it can cause some odd things. When engine and coolant are COLD (as in after sitting over night), open the radiator cap. Top off the overflow res with a 50/50 antifreeze / water mixture to HOT mark. Start engine, turn heat to hot and fan to high. Top off RADIATOR with same 50/50 mixture slowly & gradually. As the coolant circulates, it should bring any AIR trapped in the system (from heater core & engine block) to the radiator where you can replace it with the 50/50 mix. Once the coolant is HOT and stays level - about an inch under the opening, close the radiator. Monitor the overflow res and add as needed. Good luck!
2answers
Heating is not working on my 2008 saturn aura was working fine then it just stopped now it comes an goes an my temperature gauge is fluctuating between hot an cold but the car is not overheating...what is...
check coolant level sound like engine low on antifreeze.make sure coolant overflow jug coolant level full cold mark.if overflow jug empty more likely radiator low on coolant allowing air in the cooling system.
2answers
2002 ford windstar sel overheating
first check coolant level in radiator coolant level sound low.if coolant overflow jug empty.coolant sysyem low, when add coolant to coolant overflow jug coolant level should stay at full cold mark.if coolant level okay,engine overheat while sitting or moving in slow traffic either coolant fan relay or fuse could be bad.or engine coolant temperature sensor could be bad. coolant sensor turn on cooling fan at certain temperature.hot wire check to make sure cooling fan motor not bad or short in wires.if all is good have pcm check it controls fan relay to through the coolant temperature sensor signal when coolant get hot.
Need to know if i need to bleed the cooling system, after installing the radiator?
ADD COOLANT IN THE COOLANT OVERFLOW JUG UNTIL COOLANT LEVEL STOP DROPPING AND COOLANT LEVEL STAY AT THE FULL COLD MARK.PLACE COOLANT OVERFLOW JUG CAP BACK ON JUG.CRANK VECHICLE UNTIL ENGINE START WARMING UP. STOP ENGINE WAIT FOR A WHILE UNTIL COOLANT COOL DOWN TO KEEP FROM GETTING SCALDED. USE A LARGE RAG OVER THE OVERFLOW JUG CAP OPEN OVERFLOW JUG CAP A LITTLE AT A TIME REMOVE OVERJUG CAP CHECK COOLANT LEVEL ADD MORE. COOLANT IN THE OVERFLOW JUG.THEN START VECHICLE AGAIN.LET ENGINE IDLE UNTIL TOP RADIATOR GET HOT.THEN THERMOSTAT WILL BE OPEN.WHILE ENGINE IDLING WATCH THE TEMPERATURE GAUGE IN VECHICLE IF TEMPERATURE GAUGE START CLIMBING IN THE HOT ZONE.TURN OFF VECHICLE LET IT SET A WHILE THEN USE LARGE RAG REMOVE OVERFLOW JUG CAP.ADD MORE COOLANT, PLACE CAP BACK ON START VECHICLE AGAIN KEEP DOING THIS PROCEDURE UNTIL TEMPERATURE STOP CLIMBING HOT ZONE.AND WHEN COOLANT LEVEL STOP DROPPING IN THE COOLANT OVERFLOW JUG.AIR IS OUT THE SYSTEM, BUT KEEP COOLANT LEVEL IN THE COOLANT OVERFLOW JUG AT THE FULL COLD MARK.DONT OVERFILL.DONT LET COOLANT OVERFLOW JUG RUN DRY IF SO AIR WILL ENTER COOLANT SYSTEM BECAUSE COOLANT LEVEL WILL BE LOW ENGINE WILL START OVERHEATING.
CAR RUNNING HOT AFTER I CHANGED A BAD RADIATIOR OK RADIATIOR HAD A WHOLE IN IT WE CHANCED IT BUT NOW ITS RUNNING HOT HOW DO I PROPERLY REFILL THE RADIATIOR
CHECK COOLANT LEVEL STILL LOW.ADD MORE COOLANT.UNTIL RADIATOR OVERFLOW FULL AT COLD MARK.THEN CRANK ENGINE UP LET IDLE FEW MINUTES LOOK DOWN COOLANT OVER FLOW JUG ADD MORE COOLANT IF LEVEL DROPPED.WHILE ENGINE RUNNING KEEP EYE ON TEMPERATURE GAUGE.WHEN THERMOSTAT HOSE GET HOT.TURN OFF ENGINE WAIT A LITTLE WHILE TO KEEP FROM GETTING SCALD TAKE LARGE RAG PLACE OVER OVERFLOW JUG RADIATOR CAP.OPEN CAP A LITTLE A TIME.IF COOLANT TRIES BOIL OUT.LET VECHICLE SET A WHILE LONGER.ADD MORE COOLANT.WHEN COOLANT LEVEL CORRECT AND ALL AIR OUT THE COOLANT SYSTEM.IT WILL STOP OVERHEATING.LONG AS ENGINE RUNNING HOT TURN OFF THE ENGINE POUR IN MORE COOLANT UNTIL COOLANT LEVEL STOP DROPPING IN RADIATOR.KEEP COOLANT LEVEL IN OVERFLOW AT COLD MARK.DONT OVER FILL OVERFLOW JUG.
2helpful
2answers
Heat is not working - coolant was low so filled it.... problem here... heard something about an air pocket
If you dont have an external coolant leak anywhere under your hood that has shown up on your driveway it could be the intake manifold or the headgasket leaking. Also check the thermostate to solve the heat issue.
7helpful
4answers
2004 Chevy Impala no heat from defrost or heater
No heat is often a symptom of low coolant, usually followed by overheat. There are other controls that regulate heater, but right now, re-fill the cooling system with engine running and heater on high, then check for leaks (coolant you lost went somewhere...you need to determine where) Low coolant will damage your engine. Take care of that first, then if heater still does not work, then do diagnosis on that. (if you loose the engine heat won't matter, will it!)
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
