SOURCE: How to transfer videos on JVC Everio GZ-MG21U camcorder to DVD
YES!!! I GOT IT!!! Ok so the comp doesn't recognize the damn camera. I went around the problem!!! OOO so excited!!! Ok sooo simple, you'll slap yourself! Ok. First plug in your USB cord to the comp and you'll see the options play on pc, pc connection, etc. Select CREATE DVD! (You won't be able to see or select any of the files you are going to import, oh well.) You should see the regular screen pop up that says import, create, view pictures. Click IMPORT PICTURES. It will automatically import both pictures and video. For file name write something you can easily locate, ex: AAAAAAAAAAAAAA (you can change it later) Then open MOVIE MAKER. Click on IMPORT on the upper left hand corner and you'll see their demo video listed. Click on picture and video files on the bottom right hand corner and select ALL FILES. You should see what was downloaded!!! YAY!! I haven't burn a DVD yet but the files are there and the program should do it from there!
Save yourself a lot of frustration. If you have this camera change the extension of the files from .mod to .mpg and it will be compatible with a lot more video editing programs.
SOURCE: unable to export video from camcorder to PC
Get a 4-pin Firewire cable. Plugs in just below power plug slot. What plug you need on the other end depends on your computer. You can get Firewires in 4 to 4 pin; 4 to 6 pin, and 4 pin to USB. My laptop is configured to take a 4 or 6 pin Firewire but my desktop only has USB. I transfered using 4 to 4 pin and it worked great. No drivers, no discs needed...at least with Vista. As soon as I plugged in the camera, I was asked to whether I wanted to transfer from biginning of tape or at currenty location. I chose from the beginning and the camera automatically rewound and strated to transfer to the PC. I don't know if it would work same way with 4-wire Firewire to USB but assume it would. Cables around $35 but I purchased at Circuit City for the going out of business discount. I also bought some SD cards so I can take snapshots and transfer them too for print.
Get a firewire and you should be fine.
C
SOURCE: Can I stream live video from Firewire interface?
Veodia’s recently released streaming-video software is easy to use. Really easy. We’re talking plug-and-play easy. Plug your DV camera into your computer and put it in record mode. Log into Veodia.com and hit “new broadcast.” And you’re live. Instantly. And when you’re done, you hit stop and the video you’ve just streamed is available on demand through your favorite RSS feeder. Instantly. And it works.
When you hit “start broadcast” Veodia takes about 5 seconds while “detecting bandwidth.” The end product is a 320 x 240 live video feed streaming right out of your Firewire DV camera or webcam. This video is embeddable anywhere, meaning you can have this live feed be part of your blog and your viewers don’t need to be registered Veodia members. And each broadcast comes built in with a chatroom for your viewers to interact with you, the webstar, live.
The USB streaming driver for the Camcorder is not available
for Windows 7 OS from Sony at this point. Hence it is not possible to transfer
videos using USB interface. You may use i.LINK or A/V interface to transfer
videos from the Camcorder to the Computer which is running on Windows 7
Operating System.
Please
follow the steps to transfer video to a computer using an i.LINK connection
(IEEE 1394).
IMPORTANT: Video capture software and a compatible video capture card must
be installed on the computer. Depending on the computer manufacturer, various
video capture cards and software (Adobe Premiere, Roxio Video Wave, Microsoft
Windows Movie Maker, etc.) may be available or already installed on your
computer. If necessary, contact the manufacturer of your computer for further
information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate Motion or DVgate
Plus software for video capturing. Some VAIO computers also include Click To
DVD software that will allow video capture to the computer hard drive or
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
NOTE: The computer i.LINK ports and capture cards
may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK
ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will
be necessary to use a 4-pin to 6-pin i.LINK cable.
It should now be possible to copy the video using
the video capture software if the computer hardware and software are configured
correctly.
Thanks for understanding. Please let me know if you require any further assistance.
Operating System.
Please
(IEEE 1394).
information.
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
correctly.
Thanks for understanding. Please let me know if you require any clarifications.
Operating System.
Please
(IEEE 1394).
information.
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
correctly.
