ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Default 6 Digit Security code: 000999 or 1122
Hi on the back of your phone under the battery you will have your imei number, if you let me know what this number is i can then use some software and generate your own unique master code, this code will remove the security code and reset it to what it was when new,
this code wont work if you have entered the wrong code more than 5 times if you have done this then the phone can only be unlocked using leads and software.
so if you want me to give you your master reset code then you need to give me the imei number off the phone, this is under the battery on the sticker.
the imei number will be able to tell me if the phone is stolen or not but if it comes back as stolen then i wont be able to give you the unlock code, if it is not stolen then i have no problems in getting you the master security code.
hi pittadd; the default security code of nokia phones is 12345, if it will not work.try this code here...0203416706 ( this code is for your imei only)
i haven't tried doing it because i don't have a nokia phone, you should be able to set your security code again right after you enter the 10 digit numbers. i wont guarantee 100% working, hope it helps
hi, i can give you the master code but you need to read this first ok. 1. the master code wont work if you have entered 5 wrong codes as the phone will be hard locked and can only be unlocked using flash lead and unlocking software. 2 the code only works if the phone asks for security code when first swtched on.
If you have not entered 5 wrong codes then this master code will reset the security code and remove it unless you want to put another security code back on the phone. enter this code when asked for security code ok 4365426660.
This code will only work with your imei number as every single phone has a unique master code based on the imei number ok so double check the imei number before trying the code. Any problems just give me a shout back ok.
Hi here is youy master code for that imei number 2616474207.
This code wont work if you have entered the code wrong more than 5 times and it only works if the phone is asking for the code when you switch it on ok
If the code dont work check imei is correct and if you have entered the code wrong mre than 5 times then your going to need flash lead and unlocking software ok.
Hi i can help you as long as your phone is asking for the code as soon as you switch it on if not then the master code wont work its only if the phone is asking for the code when its switched on. It also wont work if the wrong code has been entered more than 5 times ok your master code for you phone and imei number is 1072517604 enter this when asked once the phone has powered up ok. If this isnt the code you need and you want to change the security code on the phone then to find out what the security code is is by buying flash lead and unlocking software the code i gave you only works if its asked when the phone is first switched on also the code resets the security code to what it was when phone was new usually 12345 or 1234 or 0000 depending on the original network that the phone was on. Let me know if you need further assistance
hi if its the master security code your after if its the code when you switch the phone on and its asking for security code this is the security code for your imei number this code wont work in any other phone as its only usable on your imei number the code is 1355603027 let me know if you need further help
