Ibought a laptop and need to change my password
When you boot up to the log in screen type in administrator as the user to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings. Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. If it fails, then try to remove the battery for at least one hour. click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password or You need to prepare: hope it helps. don
or if you still cant get past this password
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
don't forget to vote
