SOURCE: error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
SOURCE: roller marks on paper
Hi, Sounds like your problem is not the rollers. If its marked on the pages, its not the pickup rollers nor the Exit rollers that leave marks.
Either 1 you have a bad Toner Cartridge. or 2 Fuser sleeve is bad and needs to be replaced.
(1) If the toner cartridge is refurbished that is your first indication that you should replace with a HP Manufactured Toner. Refurbished toners always go bad. In fact many of them do not even last the amount they are said to last.
(2) If its not the toner cartridge, then the only other thing that is fusing roller marks is the fuser. In order to do this. You will have to remove the back panel. Unscrew the fuser.*note fuser can be extremely hot after use. be careful.* From this point you should be able to look at the Fuser sleeve and see a worn out sleeve on the side which your roller marks are at. You will either need to replace it if it looks bad. Or you can clean it when its got with a piece of paper or an alcohol pad to remove excess toner clocked on the fuser.
That toner is whats showing up as roller marks on your prints.
I hope this helps. PLEASE RATE Porfavor :)
Victor C.
If you need more detailed help please comment back ill be willing to help. I like helping others.
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
SOURCE: hp 6310 officjet all in one paper jam error
This video won't help if it's really broken, but shows you what to do for a recurring jam on the 6310.
SOURCE: My HP PS C4180 all-in-one paper jam error
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
