I have a alarm on my printer hp 3030 and i want to fix the unit scanner . how i can do it?
SOURCE: HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
press Enter bottom
press left arrow key twice
press enter key
select the language you need then press inter
SOURCE: HP 3030, network scanning
You can fix that if you go in main control panael of printer .....
SOURCE: hp 3030 scanner
Go to HP and download proper software, and drivers there is some scanner software in there to make scanner work.
SOURCE: HP 3030 Won't Scan
you may want to check that printer is plugged directly into the wall socket, NOT the power strip. this can cause some issues.
