Using a screw driver remove screws to detach the thing that locks the attachments into place. You will see a rubber seal around the socket in which the auger is fitted. Remove the seal and put a little oil on it. Replace everything after doing the lubrication.
remove to arm that holds top slide it twards you then use tool to remove blade then remove juicing screen then the bowl (the one that says jacklallanes power juicer
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
