Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Robert Carter Posted on Oct 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rusted on brake roator
Cant get it to come off
Clyde Ottaway
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Craftsman Master 1,669 Answers
  • Posted on Oct 31, 2017
Clyde Ottaway
Craftsman Master
Level 3:
Loyalty:
Answers
1669
Questions
41
Helped
490976
Points
2465
Cant get the parking brake to release
If the car has been sitting for a length of time especially in wet regions chances are either the brake mechanism or the cable that goes to the rear brakes have rusted and seized up. If the brake actuator itself Weatherby by foot or hand brake or not moving then chances are it's something in one of those two items. You will probably need to pull off the rear wheels and check that the parking brake mechanism is free moving
How to take the brake drums off
They are probably rusted on, but if not it is the brake shoes catching on a groove that was worn in over time. Make sure the emergency brake is off, if you can move drum at all its the shoes dragging, if you cant move at all, there rusted on, either way a good mallet is your ticket...
3answers
My brakes are grinding
Depending on the car you may have a bad wheel bearing. GOOD LUCK FRIEND.
2answers
Cant find a digram of brake lines on a 1997 dodge carervan
Why would you need one?
If they rust out, you replace them,
by cutting,bending,and flairing brake line tube.
Cant get front right drum off to replace stripped studs
is the drum stuck on by rust try tapping it with a hammer.
you may have to use a brake adjusting tool and back off the brake shoes to allow the drum to come off.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
2answers
The odometer isn't working on my 1993 mercury cougar. Where might
See this allot at the Ford dealer, the speedo must come out for repair.
Adjusting drum brakes, finding adjuster?
You must make sure that your hand brake cable is retracted all the way, most of the time that is the problem the cable is partially or totally seized and the brake shoes cant come back in place. Or with the help of someone else, push gently the brake pedal and see if the brake cylinder is working, the piston of your cylinder could be seized in the rust .
good luck !
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
