I own one of these and lost my combination but the safe was open. It's incredibly easy to pop open the safe and get the combination in this state - I put a video on YouTube showing how to do it -- http://www.youtube.com/watch?v=kmBHwiWgGKM
Sentry Safe lost combination. First, find your sentry floor safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
SOURCE: have a digital combination sentry safe it's lock
You just need to call a good safe and vault tech that can fit a key to your sentry safe
SOURCE: How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
SOURCE: I WANT TO CHANGE COMBINATION ON MY SENTRY FIREPROOF SAFE HOW?
I have a sentry safe csw 4747 Idont no tha combination
how do I do the safe a key and electronic key pad
