The problem is that the ram memory in the phone is running low the cure to the problem is to delete browsing history and call logs then take the battery out (called a soft reset) when the phone reboots it will b faster and you will see the hourglass alot less its good to do atleast once a wekk
I also have the same issue it seems to be sonething that all of the balckerry pearl 8100's do but it helps if you keep your inbox not too full
