Razor 300001-SL Ground Force Go Kart Logo
I'm working on a trail master gokart it will start then shut rite back off. Push gas in it will start but won't reve it act like it missing clean carb same thing got new carb same thing
1helpful
Carb on big bear 350 quad was plugged from sitting ,took apart and cleaned ,bike won,t idle unless choke is out a bit ,but if you push choke in and keep reved up will run ,also backfires when letting off...
it is a garantee that the main jet is stoped up with that grayish dried gas minerals..this not in the main jet valve you can remove,but actually in the bore on the carb body... you can try to use torch tip cleaner to open the hole ...hope you the best ....it is a very hard substance...someone tried starting the bike after being set up for a while without removing carb and cleaning first.....sincerely;R.B.V.
May 18, 2013 • Motorcycles
Murray tiller wont start
first check for spark if no spark check the oil some have a low oil shut off next try and spray some carb cleaner if it fires on that you may need to clean the carb
May 16, 2012 • Garden
4helpful
2answers
HI there, I got a lawn mower mtd yard machine briggs ans stratton 4,5 hp, it start pretty well but won't stay running, I change the spark plug, oil, gas brand new, clean the carburator, clean the air...
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
McCulloch EB358A starts but acts like it is running out of gas
ok you have what sounds to me a blockage in the carb. take it off and thouroughlly clean it. check the diaframs in the carb to see if they are hard and stiff. if they are hard and stiff replace them and clean the carb really well and see if this works.
Oct 24, 2009 • Garden
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
