Input=cable; via onscreen settings; picture size is set to 16:9 and have reset both ZOOM options BUT Picture image vs screen size is NG L&R & maybe T&B. eg, box scores at Top OR Bottom Left are only half there. Other house TVs similar conditions do NOT have this problem. Samsung online chat gave me no answers.
Go to setup menu and look for horizontal and vertical size adjustment. try adjusting.
rdjagger; good idea but on this Model#=LN32A300J1D have looked but not found any opt to simply adjust HOR or VER picture size (or ASPECT RATIO).
Using OnScreenSettingsMenu; only (4) active items under OnScreenSettingsMenu>Picture>PictureOptions>Size are:
>16:9(sets 16:9 format);
>Zoom1(enlarges 16:9 vertically);
>Zoom2(enlarges Zoom1 vertically);
>WideFit[GrayedOut=NotA];
>4:3(sets 4:3 format);
>JustScan[GrayedOut=NotA]
thanks;Steve
second paragraph on page 21 says you can adjust vertical and horizontal positionhttp://downloadcenter.samsung.com/conten...
Try getting the onscreen menu up and then going to the aspect ratio setting
change that until the picture fits the screen
go -ok then exit
Bill, Good idea but no ASPECT RATIO item found in Onscreen Settings menu for this Model#=LN32A300J1D (~2010?).
talk with a tv repair shop and find out how to change the aspect ratio
if it is automatic adjustment set by the circuitry then there may be a fault in the system
Thanks Bill; Should Model=LN32A300J1D be enough for SAMSUNG (or a repair shop) to know "if ASPECT RATIO is adjustable without having to replace defective parts"?
I would find an authorized service agent for samsung and discuss it with them
They would probably have a better knowledge of the problem any way as they are the front line repairers of the product whereas the manufacturer does not get that sort of feed back
however you can try both options to get different views on the fault
Bill, thanks for your thoughts & advice..Steve
