Motorcycles Logo
Matthew Freeman Posted on Sep 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do I pre mix the 2 stroke fuel on a peewee 50 or does the petrol go in the tank an oil in the bottle in front of forks
adam bikedoc
Level 3:
  • Motorcycles Master 695 Answers
  • Posted on Oct 27, 2015
adam bikedoc
Motorcycles Master
Level 3:
Answers
695
Questions
Helped
154042
Points
2058
The 2 stroke oil goes in the bottle at the front but i would check its bled at the oil pump and working by checking it is pulsing from the oil injection pipe before playing on it.otherwise premix it in the fueltank to be on the safe side.
5 Related Answers
Editor925
Dean
  • 285 Answers
  • Posted on Jun 24, 2009
SOURCE: 2 cycle oil to gas mixture ratio
40:1 for a McCulloch 3214.
tombones
  • 3567 Answers
  • Posted on Jul 12, 2009
SOURCE: Two stroke ratio
The standard ratio is 32 to 1. That equals 4 ounces of two stroke oil per gallon of gas.
Top rating Pls.
Anonymous
  • 2220 Answers
  • Posted on Feb 28, 2010
SOURCE: what fuel do I put in the chain saw ie petrol oil
50:1 =:
1gallon premium fuel to 2.6 ounces of quality 2-cycle engine oil
4 liters premium fuel to 80CCs of quality 2-cycle engine oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Anonymous
  • 440 Answers
  • Posted on Apr 24, 2010
SOURCE: my gilera stalker (49cc) may need an oil top-up.
There is a max mark on the 2 stroke tank visible through a slot in the fairing.
If you cant see that then fill with NEAT oil (no petrol) to within 2 inches of the top, this will last ages
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
Testimonial: "very rapid assistance - thanks!"
Anonymous
  • 311 Answers
  • Posted on May 03, 2010
SOURCE: WHERE DO DO YOU PUT THE 2 STROKE OIL MIX IN A SHERCO SM50
hi i dont know these bikes personally but,they will have a seperate tank for the two stroke oil,you will probably find it behind one of the side covers,do not put it directly into the fuel tank,that will cause all sorts of drama,as the oil(being heavier than the fuel)will sink straight to the bottom of the tank,fill the carb with oil,then you will never get it started,hope this helps...cheers
1helpful
JCB M25 strimmer, bought second hand does anyone know the fuel mix ratio please ?
TO MIX THE FUELSee Figure 3.? The product is powered by a 2-stroke engine and requires pre-mixing petrol with2-stroke oil. Pre-mix unleaded petrol and 2-stroke engine oil in a clean containerapproved for petrol.? The engine is certified to operate on unleaded petrol intended for automotive usewith an octane rating of 91 ([R+M]/2) or higher.? Do not use any type of pre-mixed petrol/oil from fuel service stations, such asthe pre-mixed petrol/oil intended for use in mopeds, motorcycles, etc. Do not useautomotive oil or 2-stroke outboard oil.? Use only synthetic 2-stroke oil.? Mix 2% of synthetic 2-stroke oil into the petrol. This is a 50:1 ratio
Feb 12, 2019 • Garden
2answers
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 • Garden
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
2answers
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 • Garden
3answers
How much oil do I ideally put into a full gas tank on my 2 stroke Kymco Like 50? can you put too much?
Hi, not familiar with this bike,does it not have a separate oil tank,?, if your machine is pre mix this means you mix the correct amount of oil and fuel together as. Single form of lubrication, this way the oil gets directly to the engine parts, when the fuel,oil,and air mixture enter the engine the spark ignights it and the engine running process is started, the mixture is atomized to a form of mist, to much oil would render the mist to sticky, and seizure may occure from overheating, as would also be the case for to little oil, MY RESEARCH DOES NOT COME UP WITH A 4T 2 STROKE
ONLY A 4 STROKE WHICH OBVOUSLY HAS NO OIL ADDED TO THE PETROL.
1helpful
Could you please let me know. 1] Can I use E10 fuel in my new RLT 30 CET 30cc trimmer that I have just purchased and am yet to start up? 2] Is 50 to 1 50mm of oil to one litre of petrol?
Hi and welcome to FixYa, I am Kelly
First off the engine is designed to operate on unleaded fuel. The manufacturer makes no statements at all about E-10 Fuel. I will tell you from experience that you can use E-10 Fuel but.... should you ever have a warranty claim make sure the entire fuel system is 100% unleaded pre-mixed fuel. Your not going to hurt the unit using E-10 fuel as long as you maintain the proper fuel-oil mixtures. If anything a splash more of 2 stroke oil as in 22 mm / liter vs 20 mm. Or (+) 8 mm per gal.
Manufacturers statemenrts and recommended fuel mixtures below:
Thanks for choosing FixYa,
Kelly
n This product is powered by a 2-stroke engine and
requires pre-mixed petrol and 2-stroke lubricant . Premix
unleaded petrol and 2-stroke engine lubricant in
a clean container approved for petrol.
n This engine is certified to operate on unleaded petrol
intended for automotive use with an octane rating
of 87 ([R + M] / 2) or higher.
1 Litre + 2 0 ml =
2 Litres + 4 0 ml =
3 Litres + 60 ml = 50:1 (2%)
4 Litres + 80 ml =
5 Litres + 100 ml =
The full operators manual is here:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
The person I bought it off said it takes 50 to 1 don't know how to measure that
50 to 1 means that for every 1 unit of (2 Stroke) oil you use 50 of the same units of petrol. Most 2 stroke oil bottles have a measure on the side which you use to measure how much oil you're using so for 5 Litres of petrol (approx 1 gallon) you would use 100ml of oil.
50 to 1 which is usually written as 50:1 is a very light mix. Husqvarna saws use 40:1. You need to use good quality 2 stroke oil from tool hire shops rather than the cheaper stuff you can buy at petrol service stations. Some makes of 2 stroke oil, like Stihl, have a measuring cup on them with ratios marked on the side. To fill them you take the cap off the measuring cup and fill to the mark at 50:1 by squeezing the oil bottle. Then pour that into 5 litres of petrol. You can also buy mixing bottles in some hardware stores with ratios marked on them. You fill the oil up to the mark 50:1 and then fill it up with petrol to get the right mix.
Dec 23, 2010 • Garden
Do i mix the casstrole oil with the petrol for the aprilia 125
It depends if you still have a pre mix tank already fitted. Mine came with the pre mix tank taken off. It is a white coloured container in a fairly flat shape on the 98 model which should be underneath the seat when you lift it. Not sure about newer models. It should have 2 stroke oil in (quite often pink). If not I have been advised to mix the 2 stroke with the petrol at about 50:1 ratio, however I would check with your local motorcycle shop or Aprilia dealer. Alternatively get a workshop manual for the correct year of bike and it will give you all the information you need in there. Also if the tank runs to empty it has to be bled otherwise if air is in the pre mix tank it can cause damage to the engine.
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
