The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it. That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record. Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data. regards
If you can afford it purchase a TIVO. I had a a video and dvd player and it drove me mad. This unit records 2 programs at once with just the press of a button. you can watch tv at the same time. Also you can rewind situations on live tv to watch it again. Top unit. I am 73 and I have no problem using it. Love it!
try sothink dvd moviemaker software or dvdvideosoft software from www.cnet.com/download.....most dvd recorders will burn (check your manual for the correct type (+ / -) and brand that works best)...but wont let you play on other machines unless you format and the other machine is just as new as the recorder...(our older dvd players will not play these new dvd)
turn off and, unplug your DVD recorder remove the six screws holding on the top tilt the back of the top up disengage the front of the top and set it aside look for a small laser tag this will point to a 1/4 inch glass lense this is the laser taking rubbing alcohol on a q-tip gently clean the lense with a twirling circular motion
i have a problem recording from dvr to dvd. i have a coxial from dvr to dvd recorder to tv . but the dvd recorder acts like it has no signal.also on the bottom of the tv screen it comes up copy protected. what the problem
I have got exactly the same problem. Thought I had found some discs that worked as the first one formatted, since then all have come up with that crappy error protection message. Samsung really should sort this out.
