probly the heater core when car is warmed up turn heat on and fell of heater hoses going in to the fire wall both should be hot if only 1 is it needs a core.
tried to unplugged the tv for a while to reset excessive voltages in the power supply as will as through the circuit. and then re plugged it again then power on, press any button. if still doesn't turn on take a look at the indicator if how may times does it blinks. it will help out to solved the main cause. the noise that you hear could be the relay in the power supply is trying to turn on. but something error in the circuit was being detected. so the blinking code can help us to determined where you gonna check.
If water is back up above the intake, it should prime itself in a few minutes. As long as you don't let the case get hot to the touch it should be okay to run dry.
If it fails to prime and pump up pressure, you may have to prime it.
It sounds like your fuel pump is bad. The fuel sending unit, which tells your gas guage how much gas you have is integrated into the pump so when you replace the pump it will fix both problems.
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens is little bent to the side. I want you to put pressure on the cam to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
sound very much like the C.R.T is low emission the tv monitors the tube before showing a picture.either get the tube boosted or changed most tv shops should do i
