Weather Channel 101-147TWC Lollipop Garden Thermometer Logo
Mary Barry Posted on Aug 28, 2015
How do I recalibrate it? - Weather Channel 101-147TWC Lollipop Garden Thermometer
2answers
How can I recalibrate my 2001 deville
recalibrate what , PCM/ECM ? engine computer . Disconnect battery cables and touch them together for 10 min.
Requires calibration
Mike, recalibration is not something you can do at home.It takes specialized equipment. Most manufacturers perform this service for little or nothing. The recalibration must be certified as correct. Contact the manufacturer, to see what their policy is for returning it for recalibration.
Hope this helped you and thanks for choosing FixYa.
How do I recalibrate alarm after replacing battery in fob?
NO..........What is it you wish to recalibrate?. If the bike is 2007 plus there is no recal needed.If you remove the battery without removing the MAXI fuse the alarm will have problems
Oven temp low. recalibrated up 35 degrees, 375
no you need to still recalibrate the unit if your using the baking style thermo they are famous for being off 75 degrees
Does not respond to stylus
Try recalibrating the touch screen. Devices with touch screens need to be recalibrated in order to respond properly. The greater the use, the more often recalibration is necessary. I recalibrate my phone once a week. I hope this helps.
Touch screen not working
Try recalibrating the touch feature. Touch screen devices need to be recalibrated ever so often. The more it is used, the more often recalibration should be done. I recalibrate my LG VU once a week. Hope this helps.
2answers
Top Weather Channel Measuring Tools & Sensors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Weather Channel Measuring Tool and Sensor Expert? Answer questions, earn points and help others
