SOURCE: one for all remote control
Hello, you can try the search method,
you do this by either holding down the device button eg: TV or if you
have one the "magic" button for three seconds, a light should then
flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
SOURCE: kingavon remote control rc81s universal remote control
To program the Kingavon Home & Leisure 8 in 1 Remote Control RC81S:
SETUP by MANUAL SEARCH
A: Power on the device that you want to control. If it is a VCR, it must be inserterted with a tape. *(This works without a tape)*.
B: Press and hold [SET] key and press the device key (TV1 etc) at the same time.
C: The LED will be on at the moment. Then release the pressed keys.
D: Press the [POWER] key again, then release it. The remote control enters into Manual Search Mode and the LED keeps flashing.
E: Point the remote control to the device, and then press the [POWER] key. See if the device reacts or not. If it reacts, turn to step F. If not, repeat step E (press the [POWER]) every 1 Second.
F: Test other keys, if they do not work good enough, return to step A.
SOURCE: I need codes for my Dish Network remote to control
Hello, you may have gotten this resolved already, but here are some simple steps to help you out!!!!
Follow the link yo our website and you will be good to go with that remote real soon!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Hope this helps!!
Becki Barned
DISH Network Customer Service
SOURCE: searching code for 3 digit of TCL TV for installation of universal remote control
TCL has no three digit setup codes. Four digits codes for TCL are: 0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
