Photos cannot be sent via text.
I am assuming you mean SMS when you refer text.
also assuming photos not MMS.
you should be able to send photo from smart phone using Apps like WhatsApp or Instagram using Wifi.
Every Apple device can send messages to another apple device. This messages are called iMessages.
When you try to send a message to your son's iPhone your iPhone will try to send it via internet using iMessages.
In order to "tell your iPhone" to use regular text messages make sure that your son's cellular number is correctly stored in your contacts. That way if your iMessage fails, your iPhone will send it via regular text message.
You will see the difference between both because the "send" button and contact name will turn green when using regular text messages and blue when you're using iMessages.
HD7 runs on the new WP7 platform ( Windows Phone 7 ) , Unfortunately Sending pics via Bluetooth is not an option on this platform as Microsoft has disabled the feature OS wide due to security concerns ( guess they are following Apple ) .
The only other way you can send picture is by attaching the pic on an email or text ( as mms ) . Hope this helped you :-)
You should be able to send a text message with the picture attached to an email address.
to send a multimedia message/text message w. picture attached: -find the actual picture you want to send on your phone and select it -then hit your "menu" or "options" button, which should give you an option to send/share the picture -select text message or multimedia message (MMS) -in the "to" line for the text message, enter the email address you'd like to send it to -hit "send"
Depends on your service provider. I believe there is a default setting or tap the softkey to change. You may want to check on forums.motorola.com. i would also check www.motorola.com/support
Hi my wife has the same phone and she also had problems with picture messaging.and i suspect you are unable to send or receive pictures via bluetooth and it was the configuration settings also with vodafone, get them to send it again and tell them again its the multimedia configuration settings you need as it took a couple of goes to get someone helpful to send the correct settings hopefully once they do it correctly you should be up and running good luck !
That all depends on your service provider. Most Q's cannot send picture messages but you can send email with attachments. So if your service provider doesnt offer picture messages with the q then all you can do is email them to others.
