I got this watch for my birthday and it wasn't working so I bought a new battery, replaced it and low and behold it STILL DOESN'T WORK!!!! Anyone with info on the HELBROS sport watch please help. I don't have the manual but the model number is CA301278BKBK. I searched online and only found one website that was not useful. P.S. if anyone owns the manual I would love to see it, as i have no clue what the features of the watch at all.
SOURCE: Instruction Manual for Fossil Watch
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
SOURCE: Can't set Seiko Yacht Timer Sports 150
Turn knob to set on "Match" Pull out crown knob. Press both buttons for 3 seconds. When you release both buttons it will beep and both hands start moving. Press either button to stop movement. Then press the top button to set the minute hand to 12 oclock. Press the bottom button to set hours to 12. Press in crown and turn to "Time" Pull out crown and set time the same way.
SOURCE: How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
SOURCE: casio 4756 problem
Go to this site. It will ask you for your model number on the back of the watch and away you go.
http://world.casio.com/wat/download/en/manual/
SOURCE: I need a replacement battery for an original navy
If anyone opted out to replace battery in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help. In your particular case I do not see the reason why you should find the battery, because any decent watchmaker has many different batteries in stock. All you have to do is to find your closest watch repair shop and ask watchmaker to replace the battery. No need at all to send it to Luminox, as this job can be done at any watch workshop with the same precision and quality. In addition you will save money for shipping and pay less for battery itself.
Rate me, plz.
