Cars & Trucks Logo
Joseph finnigan Posted on Jul 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2006. Wires disconnected from underhood fuse box panel. How do I determine which wire connects where?
I broke wire harness clip removing underhood fuse box panel to change thermostat. Wires scattered; how do I know what colors go where?
xkikbxr
Level 3:
  • Master 788 Answers
  • Posted on Jul 13, 2015
xkikbxr
Master
Level 3:
Answers
788
Questions
0
Helped
228613
Points
2051
Not quite sure what you mean, did you break a wire harness loom that keeps all the wires bundled together or did you break an actual plug connector?
If you broke a loom clip them use black electrical tape to wrap the wires back together. If you broke a plug, go to the dealer and buy the new plug or harness. the new plug will have mew wires already attached and all you'll have to do is match color, cut, splice, solder, heat shrink and plug back in.
If you have another problem for some reason or another that I haven't hit on then I'd suggest going to your local parts stor or dealership and buy the repair manual for your car, turn to the electricl schematic section and follow your color codes from there..
Good Luck
5 Related Answers
storm88
  • 7 Answers
  • Posted on Aug 30, 2008
SOURCE: 1999 Grand Cherokee Radio Wiring Harness Diagram/Color Codes
Go to www.installdr.com and search through the diagrams in there, the site is easy to use, all you need is acrobat reader installed on your computer to use the site, it has a full explanation on every wire color and what it is
Anonymous
  • 6 Answers
  • Posted on Dec 13, 2008
SOURCE: keeps blowing 15a efi fuse 1991 toyota pickup 2.2 re
there's a short somewhere causing that amperage to go up
Anonymous
  • 776 Answers
  • Posted on Jun 02, 2009
SOURCE: Windshield Washer Pump does not operate on 02 Accent
Your Accent has rear wiper/washer.. correct? That's where the 3rd wire comes in. They sold you/you bought the wrong pump. Here's the wiring diagrams:
Anonymous
  • Posted on Jun 10, 2009
SOURCE: Right side trailer brake light does not work
Did yo check the fuse panel inside the truck its located on the drivers side dash , you have to open the driver side door, in there is a 10 amp fuse that is linked to rt trailer brakes and rt turn signal for the trailer, if the fuse is good there is a black box under the dash located on the floor on the driver side, just to the left of the break, thats where must of the plug in wire harness is for the trailer breaks!
Anonymous
  • 103 Answers
  • Posted on Jul 30, 2009
SOURCE: wiring schematic for plymouth grand voyager 1995
Is there green corosion on the tip of the wire ? Chances are the answer is yes. You will have to detach the fuse panel/box and run a new wire and connector to the fuse panel. Splice into the wire you can see, but make sur you cut enough of the wire off to get rid of the corrosion.Hope this helps.
2006 KENWORTH T800 Tractor unit. How to fix my driver side low beams. 2006 KW T800
  1. Locate the power wire that goes from the fuse panel to the passenger side headlight. Follow the wire from the headlight back to the fuse panel to determine its path.
  2. Disconnect the battery to prevent any electrical accidents.
  3. Cut the power wire as close to the fuse panel as possible.
  4. Remove the old wire from the fuse panel and run a new wire in its place. You can use the same gauge wire as the original.
  5. Connect the new wire to the fuse panel and the headlight. Make sure all connections are tight and secure.
  6. Reconnect the battery and test the headlights.
I need to know how to take the fuse box under the hood of my 2005 Chevy Impala so I can put a new one in.
Underhood Electrical Center or Junction Block Replacement
Removal Procedure
  1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
  2. Click to Enlarge
  3. Disconnect the positive battery cables from the underhood fuse block terminals.
  4. Remove the tape from the wiring harness at the base of the underhood fuse block base.
  5. Click to Enlarge
  6. Release the underhood fuse block(s) clip retainers using a small flat-bladed tool.
  7. Click to Enlarge
  8. Remove the fuse block(s) and wiring harness lifting up from the base and reposition from the base.
  9. Click to Enlarge
  10. Remove the nuts from the underhood fuse block base.
  11. Remove the underhood fuse block base from the shock tower.
  12. Click to Enlarge
  13. Remove the underhood fuse block lower front terminal positive assurance retainers using a small flat-bladed tool.
  14. Click to Enlarge
  15. Remove the plastic shields from the battery cable and buss bar terminals, using a small flat-bladed tool to release the clip retainer.
  16. Click to Enlarge
  17. Remove the bolts from the buss bar jumper bar.
  18. Click to Enlarge
  19. Remove the buss bar jumper bar from the fuse block(s).
  20. Click to Enlarge
  21. Remove the fuses from the fuse block(s) to access the buss bar terminal release tabs.
  22. Click to Enlarge
  23. Remove the buss bar(s) from the fuse block(s) using a terminal releasing tool, and pulling down and out on the buss bar.
  24. Click to Enlarge
  25. Remove the buss bar(s) from the fuse block(s).
  26. Click to Enlarge
  27. Release the clip retainers from the underhood fuse block(s) battery cable and buss bar terminals using a small flat-bladed tool.
  28. Click to Enlarge
  29. Remove the underhood fuse block(s) battery cable and buss bar terminals from the fuse block by pulling down.
  30. Remove the fuse block and lamp wiring harness from the vehicle, if required.
I copied the info from my database, sorry, it is read only, The way I copied it, read only, no pictures.
My valet mode in my Cadillac dts will not turn off. It's a 2006. Can't get to my music or my trunk won't open. Please help.
It may be the ALDL fuse in the underhood fuse block, so check that. If OK, it may be the trunk release relay in the fuse block under the rear seat - also check that.
If those are OK, the valet switch in the glove box may have failed in the open position. Remove the glove box and disconnect the wire connector from the switch; then jumper the two wires together. If that fixes the problem, replace the switch.
1helpful
My 89 civic lx keeps blowing the battery fuse everytime I connect the battery
My first guess would be a short inside the alternator, so if you have replaced it, look for a shorted wire in the harness.
Disconnect the wires from the alternator and everything connected to the battery, then connect one at a time until the fuse blows.
Could be a problem with the starter solenoid too.
I need the wiring schematics for 2006 equinox
try this site autozone. they ahve a lot of wiring diagrams. jsut go down the list until you find your diagram.
Repair Guides Wiring Systems 2006 Power Distribution Schematics AutoZone...
Low beams not working on 2006 dodge ram truck. Tested and both lights not getting any power. Can't find a fuse anywhere for them ?
I check for fuses under the hood in a box.
I found relays in the box for the parking and driver lamps, but not the low beams.
I would check the color of the wires leading to the low beams and try to match it up with the tables I sent you under 'circuit' column.
The integrated power module combines the power distribution center and the front control module. It is located in the engine compartment next to the battery.
Finally, I conclude the following may be the problem:
Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Left instrument panel bezel
    • Headlamp switch from the instrument panel bezel with the screws
To Install:
  1. Install or connect the following:
    • Headlamp switch to instrument panel bezel with the screws
      1. Torque to: 20 inch lbs. (2.2 Nm)
    • Wire harness connector
-------------------------------------------------------------------------------------------prev.gif next.gif Good luck on this repair.
2answers
How to find fuse for a 2006 chevy equinox driver's power window
power windows are not usually fused. They have a circuit breaker that controls all the windows. So if only one window is not working it is something like a bad switch or window motor. Remove the door panel and unplug the connector to the window motor and check for power and ground when activating the switch.
How do I remove the factory installed radio from 2006 Honda Pilot LX
I'm doing this from memory since it's been about four months since I actually did this.
This is for a 2005 LX. EX procedure may be slightly different.
Disconnect the negative battery cable and make sure it can't come back into contact with the negative battery terminal.
1) Remove the plastic tab (where a push button probably is for EX model) to the upper right of the radio.
2) Carefully pry off the plastic piece which surrounds the stereo. I used a thin screwdriver and sock, and slightly scraped things up. In hindsight I should have used a specialized pry tool for removing such things. I think there were four or five places where this plastic panel is clipped into place.
3) After you get the plastic panel pried off, slowly remove it. You will need to disconnect the three wire harnesses connected to the buttons / indicators on the plastic panel.
4) The plastic panel should now be out of the way. Remove the four mounting screws holding the radio in place.
5) Slowly slide the radio towards you. Disconnect the wire harness and the antenna.
6) You should be ready to install a new stereo.
As a side note, when pulling the wire harnesses apart be sure to pull from the plastic connectors and not on the wires. If you pull on the wires, they may come loose from the harnesses.
If you are hooking up an aftermarket stereo, be sure to use a wire harness to connect from the aftermarket stereo to the Pilot's harness (otherwise you'll end up having to cut off the Pilot's wire harness which isn't ideal). I'd also recommend soldering and heat shrink tubing the aftermarket stereo's wiring to the aftermarket stereo's wire harness. It takes a while longer than the crimp or electrical tape method but ensures a robust connection and no electrical shorts when done correctly.
My aftermarket stereo has a power antenna connection. This needed to be connected (the Pilot's antenna is part of the rear window and thus isn't powered) because there is a signal booster which requires power (otherwise you won't be able to tune into any AM stations and will get very poor FM reception).
1helpful
2005 impala. Rear window defroster is not working
they have a fuse and a rely make sure the wire end is on the conector on the window
8helpful
3answers
No power in driver side door
2006 jetta has a known problem with the drivers door harness being too short in the a pillar. recommend new harness.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
