Cars & Trucks Logo
Alan Christiansen Posted on Jul 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get a handbook to programme a car alarm system, of a clifford 330.3x
Huseyin Huseyin
Level 3:
  • Cars & Trucks Master 3,469 Answers
  • Posted on Jul 12, 2015
Huseyin Huseyin
Level 3:
Answers
3469
Questions
Helped
767123
Points
11197
Http://www.manualslib.com/manual/254124/Clifford-330-3x.html
take a visit to the link above, if it is of no use please repost your query
Clifford 330 3X User Manual
2helpful
4answers
I have a 1999 Skoda Pickup previously fitted with a Clifford alarm, it was running great, I switched it off then it wouldn't lock, now I can't disarm the alarm so I won't start. ?
find a shop
ask them to put the wiring back to day 1 stock oem condition.
or learn how.
buy the service manual and do it. DIY
only 2ways to regress any alien alarm on a car.
Trouble with maxim50.5x alarm
notify manufacturer --local installer ---or ask old owner
Car alarm how do tell if you have a factory or a after market alarm system
Most factory remotes have the car makers logo on them. Aftermarket will either have nothing or a brand name like Viper, clifford, avital, DEI, etc.
GTI. How can I get my Clifford alarm to operate the central locking?
My best advice is to contact clifford direct and explain your problem normally very helpful.
Key immobiliser ignition switch
Most audio mobile mechanics are trained in installing alarms as well as other things on cars part and present. It would be worth finding one and enquiring about your alarm. When you phoned Clifford I am guessing that you spoke to the receptionist and they just looked it up on their computer as the model is not stocked they probably won't help as it most likely wouldn't of had any warranty anyway. I had a 97 corolla and it had a stock alarm on it and it was good. Good luck anyway. If you are not confident enough don't touch as electrics are tricky on cars specially when taking advice that is noteface to face at the problem.
HOW TO INSTALL A CLIFFORD SIO CAR ALARM SYSTEM
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory systems .
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
2answers
I need help to reset the car alarm. There is no keyless remote. It's a clifford alrm. It started fine then when i turn the car off the alarm light was blinking and now i can't start the car
Look under the dash for a little button that youll push to bypass the alarm. If not one you will need to disconnect the alarm sysem and remove it. It is useless to you anyway without the key pad
Clifford immobiliser unlocks doors, does not start car
Find where your fuel pump relay is and check for power there. Most alarm tech's and alarm system dis engages the fuel pump at there relay's.
Simple things to check is the fuse first then go for the relay and if everything there is working properly, it could be your alarm may have gone bad or your fuel pump it self.
Good luck and hope this helps
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
