You need to unplug the washer from power for 5 minutes and see if that resets this programming error, if no joy you will need a service call to have it diagnosed.
not saying this is whats wrong with it i just found this on the internet............hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
The SWAN (SWAN Laundry only) Help Line: 01189 252545 Monday-Thursday (9:00 AM-5:30 PM) Friday(9:00 AM-4:15 PM) You will need to tell them The Make: SWAN The Model:SW2051W
Good Luck! Swan is only warrantied in U.K. and Ireland!
you can down load a file to show you how to put your washer into a srevice test mode
at appliance aid .com in the washer repair aid section line 7 you will see "GE LITTEL SWAN FRONT LOAD WASHER" click on that and you will see two down loads one of them will give you
directions and a list of the codes.
it sounds as tho water is getting intyo machine after use. there are 2 possible causes.
either
inlet valve leaking. turn water off and see if this stops water accumulating. if it does, then you need to replace valve to cure.
or
if drain is plumbed into spigot on sink trap then every time you drain sink, some of the water goes down the drain hose.
to cure, take the drain hose up as high as possible in a swan neck
i guess you have washer drain pipe plumbed into a spigot on the sink trap. if so, when you empty sink, some of the water goes down the washer drain pipe and ends up filling your machine. to cure, take the drain pipe as high up as possible under the sink in a swan neck and that should cure it. its a common problem
