On RXV3900 using the remote there is a submenu for YBA-10WH (submenu shows Trim, Pair, Connect). Selecting Pair causes the YBA-10WH blue light to flash. Once iPod has Bluetooth set to ON it then displays a box showing "YBA-10WH not connected".
First attempt to connect requires tapping this box which produces the invitation to enter a 4 digit pass code. I had several attempts using pass code for my iPhone - all failed giving message "Make sure yba-10 yamaha is turned on in range and ready to pair". I finally tried keying in a pass code 0 0 0 0 and it paired!
Once turned off subsequent attempts to enable Bluetooth were much easier requiring tapping of the box but not requiring entry of any pass code.
Turn off seems to work easiest by using the remote to select the "Connect" option on the submenu and then selecting Enter on the remote - this caues display of "Disconnected" message on the RXV3900 screen.
On
your phone, make sure bluetooth is turned on (settings, general).
While
your phone is in discovery mode, turn your bluetooth device on and put
it in discovery mode (usually you have to hold the power button for 7-10
seconds).
Your phone will find the device, and you will be
prompted to enter the devises PIN number (often 0-0-0-0). Your phone
should pair with the device then.
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control the Insignia converter.
Macs aren't compatible with everything.
So the reason it didnt find it was cause its not compatible. I mean thats my conclusions and it might be right.
Fortunately you are wrong :) On yamaha site you can see that RX-V363 has a DOCK connector, which supports both iPod docking station YDS-11 and Bluetooth Wireless Audio Receiver YBA-10.
I am having the same problem. My Yamaha RX-V665 has the yba-10 bluetooth unit. My computer pairs ok but I get no sound to the receiver. If I play my music thru windows media player on my computer it works great. I really want to use ITunes??? Anyone have any ideas to help???
