Washing Machines Logo
G
Gis George Posted on Jun 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have changed my drainage water pump, for my samsung diamond drum WA80v3 washing machine, but still it is not pumping the water properly. it shows an error code 5E
I have changed my drainage water pumpfor my Samsung diamond drum WA80V3 washing machine. but still it is not pumping the draining water properly. after some minutes it shows an error code 5E
  • 2 more comments
  • jkpearman
    jkpearman Jun 13, 2015
    Hi Gis George, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Have you checked the line for clogs?
  • Gis George
    Gis George Jun 13, 2015
    i dont know the line to check the clogs.
  • Gis George
    can u pls tell me how to check this one?
  • Gis George
    when i opened the side cover of the pump i have found 2 coins & i key.but i removed that & changed the pump also. but still the problem persists
Thomas Smithbrother
Level 3:
Top Expert:
  • Master 3,698 Answers
  • Posted on Jun 13, 2015
Thomas Smithbrother
Master
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
957312
Points
10318
Their may be something in the line, leading to the pump restricting the flow to the pump.
My front loading samsung washer doesn't run through the drain and spin cycle
Hi, there is a pressure switch which is connected to the outer drum via a length of tube, this tells the machine whether there is water in the drum or not, this can also get blocked which fools the machine into sensing there is still water in the drum when there isn't, remove and unblock this tube and this should fix your problem, because the machine won't allow the normal program to go into spin if it thinks there is still water in the drum.
Got a Samsung Diamond Drum WA80V3 after I put in on quick was and start it goes 22 minutes and when at 15 it goes toe rinse but then the machine just stop doing anything. Water still inside drum. Maks n...
The drain pump is either blocked or failed. Check the filter if it's clear then you are most likely up for a new drain pump. Here is a link to the part you need and a video on how to do it. Samsung DC31 00030E DRAIN PUMP B20 3 120V 60 NEW ORIGINAL
Why does my Samsung washing machine wa80v3 not wash, spin or drain. ?
There are a few things that could cause this, first of all check the lid switch. That is a safety thing that makes sure the lid is closed before it allows it to start washing or spinning. Some other culprits could be a clogged filter, or a broken belt ( if your model has a belt) does the machine sound like its trying to wash? or does it just turn off and do nothing like its dead? if it seems dead its more than likely the lid switch, they are about $40 and simple to replace.
Sir, I would like to ask if this samsung washing machine model Diamond Drum WA80V3 220V - 50Hz - 330W can be use in Cebu City, Philippines where the electricity power cycle running is 60Hz?
It should be fine but I'm not sure how it will work with the 220v. Be sure that the power there is 110v red to white and 110v black to white. If the power is not, it probably won't work. Good luck
2helpful
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
1helpful
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Danby add water cycle, water being pumped out.
The pump acts as the drain valve. It sounds like the pump check valve is not working and you will probably have to replace the entire pump. The pump is fairly easy to replace.
Verify that the outlet from the pump goes directly to the drain hose. If so, the only other thing you can do is remove the drain pump and disassemble it to see if something is stuck in there or something. However, this is a more advanced procedure so I would recommend against it. Replace the pump.
Top Washing Machines Experts
john h
