WSM 2000-2003 Kawasaki Stx Dl 1100 Cc Jet Ski Motor Mount Logo
Bert Northwood Posted on Jun 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get a free copy or down load a workshop manual with electrical drawings for my Kawasaki 1100 STX 2002 JT110E jet ski
The jet ski a Kawasaki 2002 built 1100 STX with carburetors (not DI) it has the Multi Function Display and not the separate dials, the build type is JT110 E made for France in 2002. I cannot locate a manual for this craft so can anyone help me with this.
  • Bert Northwood
    Bert Northwood Jun 11, 2015
    Tried this but to no avail, I have paid for three manuals which are all with the DI engine but mine is with carburetors and the wiring systems are different, thanks for you help
johnny rebel
Level 3:
Top Expert:
  • Master 10,875 Answers
  • Posted on Jun 10, 2015
 johnny rebel
Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2942469
Points
47944
Sure,but,not free,
1992 1998 Kawasaki PWC JETSKI JS JF JL JH JT 550 1100 Workshop Service...
but,if you go here and sign up,you should get it all fot free, Owner Manuals Service Manuals Kawasaki Vehicles
  • Bert Northwood
    Thanks but tried this to no avail they sent wrong wiring system to my jet ski but say I am wrong? sent them an image of the build plate and numbers?
2001 Kawasaki 1100 stx di. Had a hose hooked up to it tonight idling and reviving it up, then it started to rev up on its own for a couple of seconds. Any ideas what it might be.
You may have leaking crank seals. If they leak they can cause air to mix with the fuel before it gets to the carb, causing the motor to rev high unexpectedly.
Need wiring diagram 4 1999 stx kawasaki
Hello there,
Cannot find free ones,
Go here and for Five of your American Dollars, you can get it.
http://www.selffixer.com/jet.ski/kawasaki/1999-kawasaki-stx-1100-wiring-diagram.htm
Sep 19, 2014 • Motorcycles
Need wiring diagram for kawasaki 1100 stx ignition
Hello there,
PROBLEM WITH MY KAWASAKI 2000 1100 STX DI
the oil injection unit on these skis can fail to test you will need to empty gas tank disconnect oil feed line to inlet manifold
then make a mix of two stroke fuel to the correct ratio say 10 liters. poor in to tank and take ski for a run say 10 minutes let it rest and run again if problem persists
it is possible you have leaking or blown crank case seals you will most likely need a professional to test for
i have provided you a link for free shop manual
Owners manual for 2006 kawasaki 900 STX jet ski
You might want to post this question in a different section. This is the computer games section.
2answers
Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
14helpful
2answers
Top WSM Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a WSM Boating Expert? Answer questions, earn points and help others
