20 Most Recent
kawasaki 2010 Jet Ski Ultra 260X Questions & Answers
PROBLEM WITH MY KAWASAKI 2000 1100 STX DI
the oil injection unit on these skis can fail to test you will need to empty gas tank disconnect oil feed line to inlet manifold
then make a mix of two stroke fuel to the correct ratio say 10 liters. poor in to tank and take ski for a run say 10 minutes let it rest and run again if problem persists
it is possible you have leaking or blown crank case seals you will most likely need a professional to test for
i have provided you a link for free shop manual
Need to replace starter bendix on 1994 750 kawasaki xir
It is fairly easy to change your starter bendix. Just start by disconnecting the battery cables. Then you will remove the bolts on the flywheel cover, which also hold the starter in place, and then just change the old part out with the new one.
Jet ski troubleshooting
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Oil change
Ask the dealer if this affects the warranty.
