you have a pinched wire someplace in your wire harness. maybe a melted spot also could cause this.hot wire shorting out to ground on frame. anything you had loose lately. under gas tank , wires got against exhaust pipe, wires rubbed bare from wear ? broken wire in harness could cause it.
? 0:59 https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
? 7:13 https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
? 4:10 https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
BEWARE : STOP USING THIS TV RIGHT NOW AND CALL CUSTOMER SERVICE ENGINEER. IT MAY BE A SERIOUS PROBLEM IGNORING WHICH MAY BE HAZARDOUS TO YOU. TURN THE TV OFF, SWITCH IT OFF FROM THE WALL SOCKET (MAINS) AND UNPLUG IT FROM THE SOCKET. CONTACT SERVICE ENGINEER AS SOON AS POSSIBLE.
you have a slow short in system this can cause a fire you need to determine what circuit it is and check for either a defective part also bad electrical connection you will need to possibly replace the wire or insulate it after cause is found
I am facing the same problem with my LG 32 inch plasma TV. There is also a big 2inchX4inch oval black spot at the top centre of the screen. Please suggest any remedy and also the cause. [email protected]
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
This is also known as "Tiger Striping". Your set is running way too hot. This can also be caused by storage of the unit in a garage or other place that does not have air conditioning. Heat has destroyed the seal around the plasma screen causing it to melt and leak down behind the glass or allowed the space between the glass to become contaminated. This is not fixable. By a new TV.
probably you switch was sticking causing it to behave that way.just monitor you tv if it happen once more then it will be time to call the tech.standby my brother.
