SOURCE: how to reset an open master lock
your answer is on this site
http://www.masterlock.com/faq/lostcombo.shtml
SOURCE: Master Lock luggage lock
This PDF document explains it carefully -
http://www.masterlock.com/faq/pdf/620_630_646_647_Instruction_Sheet.pdf
Hope this helps.
SOURCE: Master lock 5400D lock box
Master lock offer a free replacement service for locks which develop a mechanical defect during normal use.
See their website here for further information -
http://www.masterlock.com/customerservice/
If the lock has been forced or tampered with to cause this problem, then a replacement is needed.
Hope this helps
SOURCE: Set luggage lock
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
SOURCE: How to reset EasyGo Travel Sentry 3-Dial Combo
well.maybe you should get a new lock because there is nothing to do with it
Have a 3-wheel combination Brinks brass lock that was locked in the open position. Although I did remember the combination for some reason it wouldn't lock the wheels would stick pressed down. All I did was put the lock in its proper combination position and tapped it shut with a hammer and it fixed it hope this helps.
