I suspect a bent shaft or the piston has jammed in the cylinder. remove the unit and have a hydraulic shop diagnose the problem
Is it out of oil?
I am thinking damaged piston rings/seals. This can occur due to age and/or dirt, water or air in system. Replace or repair piston assembly. Also thoroughly clean out fluid lines/tank.
