I was trying to power my phone on and off and when I turned it back on, it had this bootup screen. I have tried everything that I have seen online. I tried taking the battery out and restoring the system. I have cleaned the camera button and it is not sticking at all! I have tried everything... nothing is working. Do I need a new phone?
Hello, friend! I happened to see you with this problem, I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional unlock tools.
They are free to consult, I hope that the programmers I recommend can help you.
SOURCE: RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEARED ON MY SCREEN???
hey, i had the same problem and i fixed it. i took the battery out and saw the 4 golden tabs behind the battery. there was two tabs that u could pull out. i lightly pulled them out a little bit. the problem was that the tabs wouldnt hit the battery to charge it. thats why it put the tri colored screen on the front. also my charger fit into the charging hole in the phone, but it had to be moved around to much that it did not fit exactly. I have been rough with the charger so it moved the inside of my phone around. i put the charger in the phone and moved it around gently around untill the light lit up on the front at the top by the word at&t. after it was completly charged, i turned it on and it worked perfectly. i hope this helps in whoever may have this problem because i know it sucks!
Thanks
SOURCE: g1 phone camera doesnt take pictures
As the others said, there are the two settings. I had a similar problem, then realized how it worked. You need to not press very hard while it focuses first. Then you can press all the way down, if you hold it all the way down, it doesn't recognize that you've already passed the first "Focus" pressure point and gone into the second "Capture" pressure point.
SOURCE: HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset
14 January 2008
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
SOURCE: G1 TOUCHSCREEN
Hi there, You are lucky that it is on... try one thing.. put the fun under the sunlight for half an hour or may be 15 min if its too hot there and try it again...
if this will not work then try to open the phone if you can clean the top screen area and put it back (try at your own risk) and it will do..
SOURCE: my G1 cut off and now it wont come back on... when
To hard reset...turn the phone on while holding home and back. Follow on screen prompt. this will reset the phone to factory settings,
out of the box settings
hold home + power
once phone is on, open keyboard and hold alt first + w
you should call T-moble support. its probably the ahome app.
