Canon DR 3080C Path-Through Scanner Logo
Posted on Jul 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting vertical lines on scanned pages when duplex scanning on canon dr-3080c II scanner Only on duplex side of pages, though. Front page still shows up clean.
  • dgh1222 Jul 10, 2009
    Actually, I found a differnet solution. I ran the calibration sheet through the machine, and this corrected the isue. Thank goodness I didn't toss that out!
  • Anonymous Mar 22, 2014
    ble (cyan) lines on scanning
Mohan Sriraman
Level 2:
  • Expert 490 Answers
  • Posted on Jul 10, 2009
Mohan Sriraman
Expert
Level 2:
Answers
490
Questions
0
Helped
247112
Points
823
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
Color duplex doesn't work
The Canon DR-3080C is only color on the front side. The back side is monochrome only. The next model, which was the DR-3080CII will do double sided color scanning
I have a Canon DR-2080C. Black line appears on the front page but when a scan as duplex it is not on the back page. How do I fix?
The top module has dirt stuck and bottom module is clean. Please clean the scan module with Isopropyl alcohol. For emergencies take a drop of cologne on a piece of cloth and wipe the area that is dirty.
S. Mohan
Why am i getting an extra blank page when scanning?
If the 'Duplex' setting is on, the back side will also be scanned, resulting in extra blank page.
S. Mohan
I have a DR-3080C II, which I've replaced one set of rollers on to fix paperjamming issues. The scanner occassionally picks up two pages at once, scans the top one, spits both out like it was one. I'd...
What Scanning software are you using? If CapturePerfect, there is an option to detect double page. Once you select this, the scanner will STOP, if two pages are sucked in and the panel will display "d04" indicating double page. Also Wipe all the rollers with a well wrung damp cloth for every 2000 pages to remove paper dirt.
S. Mohan, Chennai, India
1helpful
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
I have a Canon DR-3080C II that the images scanned are totally black. I have tried cleaning it, reinstalling drivers, moving to a different PC, and using different programs & settings with no change. ...
Check the brightness setting. Try keeping at close to the maximum and scan. If it is still black, may be the lighting module or Scan module is affected. Check for any loose connections.
S. Mohan
Black line through the middle of the document
The thick line is either because of dust sticking to the glass or a module problem. Try different brightness settings and scan white paper. If the thickness varies and also the sides of the black strip are jaggered (step like) then it is dust on Glass. use isopropyl alcohol to clean, dont use solvents. If the teickness is same for all levels of brightness and has a sharp edge always, it could be scan module problem.
S. Mohan
I have a canon dr-3080c that will scan all but the last page have to put blank sheet of paper to complete scan job, have replaced roller kit for other problem and the kit repaired that problem but still...
I think this is rubber roller problem. Obviously, the scanner cannot find out which is the last page. If the paper available is less, the roller is not pulling the last few sheets.
S. Mohan
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
old marine
old marine
ZJ Limited
ZJ Limited
