How do I brighten the screen
SOURCE: RCA 25205 Visys will not record message
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
SOURCE: Crosstalk problems with RCA Visys 25424RE1-A
Unplug phone that has crosstalk problem.Replace with a good phone.If trouble disappears then trouble is the replaced phone.If trouble is still there,then it is wiring problem.
SOURCE: have rca visys 2 line corded phone - lost manual
Follow this link for answers and troubleshooting tips. http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=12&idproduct=14
