20 Most Recent RCA 25413RE3 Corded Phone Questions & Answers
http://www.rca4business.com/products/pc/pdf/instruction-book/25414RE3.pdf
Manual for the 25414RE3-A Corded 4-Line RCA Executive Series Phone.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jerry_779afc81ec0a7712
RCA 25413RE3... | Answered on Oct 12, 2016
Don't know about other models, but I just called RCA small business phone support (800-511-3180) to find out how to clear the message light indicator on my 25210 2-line cordless phone when it continues to blink but there is no message.
All you have to do is hold down the delete button for a few seconds and it will clear. Hope this helps someone else from going batty!
RCA 25413RE3... | Answered on Mar 21, 2015
rev iew and clear all messages
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
RCA 25413RE3... | Answered on Jun 26, 2014
We had the same problem...Each phone line needs to have a separate phone I.D. You probably have two phones with the same number or one phone does not have a number assigned to it. You can do this automatically. Press menu, phone options, then phone I.D. and press select and the system will automatically assign an I.D. to the phone. Do this for each phone on your system and the problem should be solved.
RCA 25413RE3... | Answered on May 03, 2013
I was having the same problem...no caller ID. Then I looked up the phone on the RCA site:
http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=22&idproduct=11
Turns out there is no called ID on this model =(
RCA 25413RE3... | Answered on Nov 13, 2012
The RCA 25413 phone does not have caller ID capability. I have included a link where you can download the manual. On page 16 of the manual it says in a note that caller ID does not apply to the 25413 model phone.
http://www.rca4business.com/products/pc/pdf/instruction-book/25413RE3.pdf
RCA 25413RE3... | Answered on Mar 25, 2011
Here is a link where you can download the manual from RCA.
RCA 25413RE3... | Answered on Mar 24, 2011
You can get the Service provider default code and reset it..
RCA 25413RE3... | Answered on Jan 17, 2011
If you have more than one phone then its probably flashing because the phone ID is the same as another phone on your system or not setup up yet with an ID just has two dashes (--). or you if you have more than one phone on the system and have more than 2 lines coming into the phone, they all have to be on line 1 together in the first port on the back. Communication between sets are done on line 1
RCA 25413RE3... | Answered on Dec 06, 2010
Hi Listen for a Dial Tone
  • When you pick up the receiver of your home telephonemag-glass_10x10.gif, you should hear the distinctive sound of a dial tone. If the tone is not present, one of several factors may be in play. First, ensure the line is actually available by verifying that any other telephones in the home are securely on the hook and not in use; be sure to verify that any computers or fax machines are also not in an "off hook" condition. If all other telephones and devices are securely on the hook, and at least one of those phones has a dial tone, there may be a broken telephone wire at the non-functional phone that needs to be replaced. If none of the phonesmag-glass_10x10.gif are able to get a dial tone, you may be able to test the line by plugging a working telephone into the modular telephone jack found inside your network interface device (NID) outside the home. This device is a small plastic box where the telephone company's incoming wires terminate and the home wiring begins; simply open the box and plug a working telephone into the available telephone jack. If this jack is not working, call your local telephone carrier for further service.
  • Listen for Static
    RCA 25413RE3... | Answered on Aug 03, 2010
    This phone does not have caller ID. You have to go to the next unit up to get caller ID, the RCA 25424RE.
    RCA 25413RE3... | Answered on May 14, 2010
    Check with your phone company about blocking a number. Many of them have that ability now.
    RCA 25413RE3... | Answered on May 10, 2010
    RCA 25413RE3 Corded Phone Logo
    52 questions posted
    Top RCA Lands Phones Experts
    Marvin
    Marvin
    Steve Allison
    Steve Allison
    Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
    View Most Popular
    RCA Lands Phones
    • RCA Lands Phones
    Most Popular Question
    cannot get caller id work all phones
    • Lands Phones
