Intermitent. not heat related. flat or hilly. just once in a while
SOURCE: My Silverado front end wobbles at any speed, not affected braking
Couple of checks , mud in front rims will give you a wobble. Front tire cord seperation or loose wheel nuts. , Wore out tie rod end, front wheel bearing play, or a weight has fallen off the rim and it needs balancing. If it is vibrating your steering wheel, have the front end looked at right away.
SOURCE: front end wobbles shakes and vibrates
Might try inspecting the tires making sure you dont have any tires that have separated cords. If they look OK rotate the tires and see if the problem changes at all. Hope this helps
Lefty64
SOURCE: My car front end wobbles when braking and at higher speed
did you have the front brake rotors machined, they are warped. either replace the brake rotors or have then machined, I prefer just replacing them as they are fairly cheap.
Testimonial: "Awesome, thanks I'll try that "
SOURCE: Broken brake line on 1990
1990 Chevy 4.3 l engine runs rough at idle half the time-- sometimes it's OK, other days it's rough and can smell raw gas, as tho it's running rich... any ideas?
