20 Most Recent Chevrolet 2011 Chevrolet Avalanche 1500 LTZ Questions & Answers
How to recode Chevy sunroof. Motion
Circuit/System Description The sunroof control module supplies each of the sunroof switch signal circuits with a 12-volt reference. When a switch is pressed the signal circuit is pulled low signaling the sunroof open or close request. The module determines the motor direction based on inputs received from the sunroof switch. Sunroof Motor/Actuator Initialization/Teach Process Perform the initialization/teach procedure any time: ?€¢ A new sunroof motor/actuator has been installed.
?€¢ The existing sunroof motor/actuator has been removed and reinstalled.
?€¢ The sunroof system has suffered 3 interruptions for emergency events, i.e. anti-pinch, debris in tracks etc., and normal operation is canceled.
By performing the initialization/teach procedure, the sunroof motor/actuator records the open vent stop position. The motor/actuator will then understand the other positions, closed and full open soft stop, and allow express and obstacle detection functions.
  1. Ensure that all electrical harness connectors are connected.
  2. Turn the ignition to ON.
  3. Completely close the sunroof window with the manual close switch.
  4. Press the sunroof vent switch to the vent open position until the sunroof window stops, and continue holding the switch for at least 10 seconds.
  5. Important: The initialization/teach procedure is not complete if the battery and/or ignition power has been interrupted during the process. The Initialization/Teach Process must be restarted if the procedure is not carried out completely.
  6. Verify the operation of the sunroof in all positions.
If this does nothing ! Important: Because of the accessibility of the sunroof switch, perform the sunroof switch component test before beginning the Circuit/System Testing. Power Sunroof Malfunction
  1. Ignition OFF, disconnect the harness connector at the sunroof control module.
  2. Test for less than 5.0 ohm between the ground circuit terminal 2 and ground.
  3. ?‡' If greater than the specified range, test the ground circuit for an open/high resistance.
  4. Verify that a test lamp illuminates between the B+ circuit terminal 1 and ground.
  5. ?‡' If the test lamp does not illuminate, test the B+ circuit for a short to ground or an open/high resistance. If the circuit tests normal and the B+ circuit fuse is open, replace the fuse and replace the sunroof control module.
  6. Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 5 and ground.
  7. ?‡' If the test lamp does not illuminate, test the ignition circuit for an open/high resistance. If the circuit tests normal, refer to Retained Accessory Power (RAP) Malfunction.
  8. Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 6 and ground.
  9. ?‡' If the test lamp does not illuminate, test the ignition circuit for an open/high resistance. If the circuit tests normal, refer to Retained Accessory Power (RAP) Malfunction.
  10. Ignition OFF, connect the harness connector at the sunroof control module.
  11. Disconnect the harness connector at the sunroof switch.
  12. Test for less than 5.0 ohm between the ground circuit terminal 5 and ground.
  13. ?‡' If greater than the specified range, test the ground circuit for an open/high resistance.
    Important: Apply ground to the module for no longer than 2 seconds at a time or the module could be damaged. When performing the following tests, make sure that the sunroof or sunshade is not at its end of travel position by switching the grounded jumper to the other signal circuit if the sunroof or sunshade does not move in one direction.
  14. Ignition ON, momentarily install a 10-amp fused jumper wire between the signal circuit terminal 6 and ground. The sunroof should move.
  15. ?‡' If the sunroof does not move, test the signal circuit for a short to ground, short to voltage or an open/high resistance. If the circuit test is normal, replace the sunroof control module.
  16. Momentarily install a 10-amp fused jumper wire between the signal circuit terminal 4 and ground. The sunroof should move.
  17. ?‡' If the sunroof does not move, test the signal circuit for a short to ground, short to voltage or an open/high resistance. If the circuit test is normal, replace the sunroof control module.
  18. With the sunroof in the fully closed position, momentarily install a 10-amp fused jumper wire between the signal circuit terminal 2 and ground. The sunroof should vent open.
  19. ?‡' If the sunroof does not vent open, test the signal circuit for a short to ground, short to voltage or an open/high resistance. If the circuit test is normal, replace the sunroof control module.
  20. Momentarily install a 10-amp fused jumper wire between the signal circuit terminal 8 and ground. The sunroof should close.
  21. ?‡' If the sunroof does not close, test the signal circuit for a short to ground, short to voltage or an open/high resistance. If the circuit test is normal, replace the sunroof control module.
  22. If all circuits test normal, test or replace the sunroof switch.
9/2/2016 3:18:49 PM • Chevrolet 2011... • Answered on Sep 02, 2016
0answers
4answers
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader? Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3. Hope it can be another choice for you or other users. :) Watch online videos offline freely with Leawo YouTube Downloader
4/25/2024 8:54:44 AM • Computers &... • Answered 5 hours ago
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
4/25/2024 7:57:08 AM • Computers &... • Answered 6 hours ago
Where can i get mastering machine learning Tips for Tackling Assignment
Here
The Ultimate Guide to Conquering Machine Learning ...
makexyz.com https://www.makexyz.com > the-ultimate-guide-to-conqu... Feb 19, 2024 - When diving into machine learning assignments, it's essential to adopt a systematic approach. Break down the task into manageable components, ...
7 Steps to Mastering Machine Learning with Python in 2022
KDnuggets https://www.kdnuggets.com > 2022/02 > 7-steps-masteri... Sep 30, 2022 - Step 1: Learn Programming for Machine Learning ... You need to have a working knowledge of programming before you dive into machine learning. Most ...
Machine Learning Assignment Help
Medium · Abnerassignmenthelp 1 month ago Our experts can assist you in tackling machine learning assignments effectively. Deep Learning Assignment Help: Our team of deep learning . ..
4/24/2024 8:11:03 PM • Computers &... • Answered 18 hours ago
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered Yesterday
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered 3 days ago
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered on Apr 21, 2024
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered on Apr 21, 2024
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered on Apr 17, 2024
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered on Apr 16, 2024
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered on Apr 13, 2024
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
4/13/2024 2:31:14 PM • Computers &... • Answered on Apr 13, 2024
3answers
How i free download tally
u need tally 4.5 free software (full ) if u need mail me i will give u link k
4/13/2024 2:20:33 PM • Computers &... • Answered on Apr 13, 2024
We have a Dukane Model No ACC5 Administrative Control Console and it keeps chirping. Not sure why or how to make it stop. Please advise?
This fault / alarm / warning is not listed anywhere and the company is no longer in business. Turn over the console and see if there is a door for a back up battery. It may be warning that it is running out. Do the same with the main control unit. You could also try powering off the main unit for 10 minutes to reset the software. https://www.google.com/search?q=dukane+model+no+acc5+administrative+control+console+chirping This is the unit that drives your admin console http://serialsistemas.com.br/duk/2/85101-0025%20--%20MCS350.pdf ..
4/12/2024 2:30:20 AM • Computers &... • Answered on Apr 12, 2024
2answers
To check if my sasseta certificate is registered
http://www.sasseta.org.za/ SASSETA Branch Contact Details Telephone Numbers: Call Centre: 27 (0)11 087 5555 Fax Number: 27 (0)11 205 0046 Switchboard: Midrand E-Mail: [email protected] Address & Map: Midrand Office Physical Address: Riverview Office Park Janadel Avenue (off Bekker road) Halfway Gardens Midrand 1685 Postal Address: P.O. Box 7612 Halfway House 1685 http://www.sasseta.org.za/content/tinymce/plugins/openfile/uploads/FRM_SKA_004_Application%20for%20Certificate%20Re-Issue.pdf
4/12/2024 12:53:51 AM • Computers &... • Answered on Apr 12, 2024
Would you want my fix for empowering technology pop up?
Removing/uninstalling empowering technology popup
BleepingComputer https://www.bleepingcomputer.com > forums > removin... Jul 30, 2020 - This annoying pop up started yesterday, it cannot be stopped. It blinks like a turning signal now. I looked everywhere for a fix or info on ... ..
4/11/2024 9:10:48 PM • Computers &... • Answered on Apr 11, 2024
Chevrolet 2011 Chevrolet Avalanche 1500 LTZ Logo
1 questions posted
Top Chevrolet Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Morris Lindsey
Denis Houle
Are you a Chevrolet Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Chevrolet Computers & Internet
Most Popular Question
recode chevy sunroof motion
  • Computers & Internet
