Engine in spain not a lot of problems and expect to pay around 600E to a about a 1000E .Shipping then use seur who i have found to be very good for this sort of thing
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaultsor load optimized defaults press escape then press f10 to save to cmos to restart
make sure your ram modules are seated properly with no dust in there sockets
click start right click on computer select proprties you will see ammount of ram installed and usable ram
also cmos battery is seurely seated with no dust in the socket on some motherboards cmos
batteries are soldered in
computers need power and data to travel through every working deviceand to have a finishing point to work
scroll to bottom toolbar (bottom of screen) right click select task manager applications see
whats running also applications if you see something running that should not click end now
saya lupa password, security answer, dan email alternatif.. id yahoo saya: [email protected] tolong donk di resetin passwordnya dan kirimkan ke : [email protected]
on the bottom of the ice dispenser front cover is 2 slots insert a small screw driver into these slots and carefully pry the cover off (be careful not to scratch your door) one the cover is off there will most likely be a wiring harness that you can unplug and put cover out of your way. next you will need to move the white bracket out of your way there is either 2 thumb latches or 2 screws that seure it. it will not come all the way out so you may need someone to hold it out of the way for you. in the center of both of your levers you will see 1 screw with a cardboard spacer and brass spring BE CAREFUL NOT TO LOOSE THESE! remover screw spacer and spring afte that you should be able to work the levers right on out. the ice lever is a little tricky trying to get it around the ice door but it will come out.
