How to remove rear quarter panel glass (triangle shape)? The one that is behind the rear door? How to actually remove the interior panels to get at the screws?
SOURCE: how to remove door panel for driver and passenger side doors
Hi. This Guide will help you with this issue.
Step1
Check out how the door panels are attached to the car.
Most panels use screws and bolts but others have snap-in fittings.
Gather all the tools you need for removing the door panels. If the
panel is attached with screws and bolts, you need a screwdriver or
ratchet and socket. Car door panels with snap-in fittings are easily
removed with a flathead screwdriver.
Step2
Locate where the screws and bolts are before starting. These are
usually found in the arm rest area, along the bottom or sometimes near
the door lights.
Step3
Roll down the car door window. Begin removing all screws and bolts that hold the door panel onto the car. If your car has snap-in fittings, pry gently on the bottom corner of the door panel until the fittings pop out.
Step4
Remove the power
window control panel if your car has power windows. The control panel
should pry out easily, and then you unplug the wiring harness from the
back and place it to the side.
Step5
Use an L pick and flashlight when locating a manual window crank. Look
behind the window crank and slide the pick under the edge of the metal
clip that holds the crank in place. Remove the clip and pull the crank
off.
Step6
Remove the door handle by unscrewing the small screw located in the
center. Gently pull the door handle out until you see the back of the
handle and unclip the rod from the door handle. This should remove the
handle unless the handle and door lock are attached, then you just unclip the rod from the lock and remove them both together.
Step7
Unscrew the cap off rear upper corner door panel locks. These don't
have a rod attaching them to the handle and unscrew separately from the
door handle.
Step8
Pop the door panel off after you've removed everything. Gently pry on
the bottom edge of the door panel until it releases. Pull out and up to
completely remove the door panel.
Please rate and have a great day:)
SOURCE: Removing door panel
There's actually some more screws you missed.. they'll be hidden near the door handle and the armrest that you'll need to take off...once the panel's off, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
SOURCE: remove door panel
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
SOURCE: door panels
You should find screws in the armrest and plastic push clips evenly spaced around the edge of the door panel. Use a stiff putty knife, slide it between the door panel & the door frame. Slide it left or right until you find the clip and pry up. It will pop out. When you have poped all of the clips out push the entire door panel up to disengage the top from the window edge.
